Retrieve AKV configuration for an SVM specified by the UUID
GET /security/azure-key-vaults/{uuid}
Introduced In: 9.8
Retrieves the AKV configuration for the SVM specified by the UUID. Note: This method is only available to the Azure NetApp Files Cloud Volume Services.
Related ONTAP commands
security key-manager external azure show -
security key-manager external azure check
uuid |
string |
path |
True |
AKV UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
azure_reachability |
Indicates whether or not the AKV service is reachable from all the nodes in the cluster.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
ekmip_reachability |
array[ekmip_reachability] |
key_id |
string |
Key Identifier of AKV key encryption key. |
name |
string |
Name of the deployed AKV that is used by the Azure NetApp Files Cloud Volume Services for storing keys. |
proxy_host |
string |
Proxy host. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
Indicates whether or not the AKV wrapped internal key is available cluster wide.
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
uuid |
string |
A unique identifier for the Azure Key Vault (AKV). |
"href": "/api/resourcelink"
"azure_reachability": {
"code": "346758",
"message": "AKV service is not reachable from all nodes - reason."
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"key_id": "https://keyvault1.vault.azure.net/keys/key1",
"name": "https://kmip-akv-keyvault.vault.azure.net/",
"proxy_host": "proxy.eng.com",
"proxy_port": "1234",
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"code": "346758",
"message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
azure_reachability
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster. |
message |
string |
Error message set when reachability is false. |
reachable |
boolean |
Set to true when the AKV service is reachable from all nodes of the cluster. |
node
_links |
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
code |
integer |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
state
available |
boolean |
Set to true when an AKV wrapped internal key is present on all nodes of the cluster. |
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
