Retrieve AKV configuration for an SVM specified by the UUID
GET /security/azure-key-vaults/{uuid}
Retrieves the AKV configuration for the SVM specified by the UUID.
Related ONTAP commands
security key-manager external azure show
Learn more
uuid |
string |
path |
True |
AKV UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
key_id |
string |
Key Identifier of AKV key encryption key. |
name |
string |
Name of the deployed AKV that will be used by ONTAP for storing keys.
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
Indicates whether the AKV key protection is available cluster wide. |
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
uuid |
string |
A unique identifier for the Azure Key Vault (AKV). |
"href": "/api/resourcelink"
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"key_id": "https://keyvault1.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74",
"name": "https://kmip-akv-keyvault.vault.azure.net/",
"scope": "string",
"state": {
"code": 346758,
"message": "AKV key protection is unavailable in following nodes - node1, node2."
"svm": {
"name": "svm1",
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
state
cluster_state |
boolean |
Set to true when AKV key protection is available on all nodes of the cluster. |
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV key protection is available in all nodes of the cluster. |
message |
string |
Error message set when cluster availability is false. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
