REST API reference
Retrieve the Barbican KMS configuration for an SVM
GET /security/barbican-kms/{uuid}
Introduced In: 9.17
Retrieves the Barbican KMS configuration for the SVM specified by the UUID.
  • security key-manager external barbican show
  • security key-manager external barbican check
uuid
string
path
True
Barbican KMS UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
application_cred_id
string
Keystone application credentials ID required to access the specified Barbican KMS.
barbican_reachability
Indicates whether the Barbican KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET request or an instance GET request unless it is explicitly requested using the field's query parameter or GET for all advanced properties is enabled.
configuration
configuration
Security keystore object reference.
enabled
boolean
Indicates whether the configuration is enabled.
key_id
string
Key Identifier URL of the Barbican KMS key encryption key. Must be an HTTPS URL.
keystone_url
string
Keystone URL for the access token. Must be an HTTPS URL.
proxy_host
string
Proxy host name.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
Indicates whether or not the SVM key encryption key (KEK) is available cluster wide. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
svm
timeout
integer
Connection timeout in seconds.
uuid
string
A unique identifier of the Barbican KMS.
verify
boolean
Verify the identity of the Barbican KMS.
verify_host
boolean
Verify the identity of the Barbican KMS host name.
      "href": "/api/resourcelink"
  "application_cred_id": "63e3cb77f84f42b7a0395a3efb7636f9",
  "barbican_reachability": {
    "code": "346758",
    "message": "Barbican KMS is not reachable from all nodes - <reason>.",
    "reachable": ""
  "configuration": {
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "key_id": "https://172.29.58.184:9311/v1/secrets/5c610a4f-ea97-44b5-8682-f4daeafa9647",
  "keystone_url": "https://keystoneip:5000/v3/auth/tokens",
  "proxy_host": "proxy.eng.com",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "state": {
    "cluster_state": "",
    "code": "346758",
    "message": "Top-level internal key encryption key is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
  "svm": {
    "name": "svm1",
  "timeout": 60,
Status: Default
ONTAP Error Response Codes
Error Code Description
65539801
The Barbican Key Management Service is unreachable from one or more nodes.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Code corresponding to the error message. Returns 0 if Barbican KMS is reachable from all nodes in the cluster.
message
string
Set to the appropriate error message when 'reachable' is false.
reachable
boolean
Set to true if the Barbican KMS is reachable from all nodes of the cluster.
configuration
_links
_links
name
string
Name of the configuration.
uuid
string
Keystore UUID.
state
cluster_state
boolean
Set to true when an SVM-KEK is present on all nodes of the cluster.
code
string
Code corresponding to the status message. Returns a 0 if the SVM-KEK is available on all nodes in the cluster.
message
string
Error message returned when there's no SVM-KEK availability on the cluster.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
