Retrieve the Barbican KMS configuration for an SVM
Retrieves the Barbican KMS configuration for a specific SVM to review the key management settings associated with that SVM.
HTTP method and endpoint
GET /security/barbican-kms/{uuid}
Introduced in
ONTAP 9.17
Usage notes
Retrieves the Barbican KMS configuration for the SVM specified by the UUID.
Related ONTAP commands
security key-manager external barbican show -
security key-manager external barbican check
uuid |
string |
path |
True |
Barbican KMS UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
application_cred_id |
string |
Keystone application credentials ID required to access the specified Barbican KMS. |
barbican_reachability |
Indicates whether the Barbican KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET request or an instance GET request unless it is explicitly requested using the field's query parameter or GET for all advanced properties is enabled. |
configuration |
Security keystore object reference. |
enabled |
boolean |
Indicates whether the configuration is enabled. |
key_id |
string |
Key Identifier URL of the Barbican KMS key encryption key. Must be an HTTPS URL. |
keystone_url |
string |
Keystone URL for the access token. Must be an HTTPS URL. |
proxy_host |
string |
Proxy host name. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
Indicates whether or not the SVM key encryption key (KEK) is available cluster wide.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
svm |
timeout |
integer |
Connection timeout in seconds. |
uuid |
string |
A unique identifier of the Barbican KMS. |
verify |
boolean |
Verify the identity of the Barbican KMS. |
verify_host |
boolean |
Verify the identity of the Barbican KMS host name. |
"href": "/api/resourcelink"
"application_cred_id": "63e3cb77f84f42b7a0395a3efb7636f9",
"barbican_reachability": {
"code": "346758",
"message": "Barbican KMS is not reachable from all nodes - <reason>.",
"reachable": ""
"configuration": {
"name": "default",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"key_id": "https://172.29.58.184:9311/v1/secrets/5c610a4f-ea97-44b5-8682-f4daeafa9647",
"keystone_url": "https://keystoneip:5000/v3/auth/tokens",
"proxy_host": "proxy.eng.com",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"cluster_state": "",
"code": "346758",
"message": "Top-level internal key encryption key is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
"timeout": 60,
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65539801 |
The Barbican Key Management Service is unreachable from one or more nodes. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Code corresponding to the error message. Returns 0 if Barbican KMS is reachable from all nodes in the cluster. |
message |
string |
Set to the appropriate error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Barbican KMS is reachable from all nodes of the cluster. |
configuration
_links |
name |
string |
Name of the configuration. |
uuid |
string |
Keystore UUID. |
state
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_state |
boolean |
Set to true when an SVM-KEK is present on all nodes of the cluster. |
code |
string |
Code corresponding to the status message. Returns a 0 if the SVM-KEK is available on all nodes in the cluster. |
message |
string |
Error message returned when there's no SVM-KEK availability on the cluster. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
