REST API reference
Retrieve Barbican KMS configurations for all SVMs
Retrieves Barbican KMS configurations across all SVMs, which helps you understand and manage key management settings in a multi-tenancy environment.
HTTP method and endpoint
GET /security/barbican-kms
Introduced in
ONTAP 9.17
Usage notes
Retrieves Barbican KMS configurations for all SVMs.
  • security key-manager external barbican show
  • security key-manager external barbican check
application_cred_id
string
query
False
Filter by application_cred_id
scope
string
query
False
Filter by scope
state.message
string
query
False
Filter by state.message
state.cluster_state
boolean
query
False
Filter by state.cluster_state
state.code
string
query
False
Filter by state.code
uuid
string
query
False
Filter by uuid
barbican_reachability.code
string
query
False
Filter by barbican_reachability.code
barbican_reachability.reachable
boolean
query
False
Filter by barbican_reachability.reachable
barbican_reachability.message
string
query
False
Filter by barbican_reachability.message
proxy_type
string
query
False
Filter by proxy_type
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
key_id
string
query
False
Filter by key_id
proxy_username
string
query
False
Filter by proxy_username
verify_host
boolean
query
False
Filter by verify_host
timeout
integer
query
False
Filter by timeout
verify
boolean
query
False
Filter by verify
proxy_host
string
query
False
Filter by proxy_host
keystone_url
string
query
False
Filter by keystone_url
enabled
boolean
query
False
Filter by enabled
configuration.name
string
query
False
Filter by configuration.name
configuration.uuid
string
query
False
Filter by configuration.uuid
proxy_port
integer
query
False
Filter by proxy_port
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[barbican]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "application_cred_id": "63e3cb77f84f42b7a0395a3efb7636f9",
      "barbican_reachability": {
        "code": "346758",
        "message": "Barbican KMS is not reachable from all nodes - <reason>.",
        "reachable": ""
      "configuration": {
        "name": "default",
        "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
      "key_id": "https://172.29.58.184:9311/v1/secrets/5c610a4f-ea97-44b5-8682-f4daeafa9647",
      "keystone_url": "https://keystoneip:5000/v3/auth/tokens",
      "proxy_host": "proxy.eng.com",
      "proxy_port": 1234,
      "proxy_type": "http",
      "proxy_username": "proxyuser",
      "scope": "string",
      "state": {
        "cluster_state": "",
        "code": "346758",
        "message": "Top-level internal key encryption key is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
      "svm": {
        "name": "svm1",
      "timeout": 60,
Status: Default
ONTAP Error Response Codes
Error Code Description
65539801
The Barbican Key Management Service is unreachable from one or more nodes.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
Indicates whether the Barbican KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET request or an instance GET request unless it is explicitly requested using the field's query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns 0 if Barbican KMS is reachable from all nodes in the cluster.
message
string
Set to the appropriate error message when 'reachable' is false.
reachable
boolean
Set to true if the Barbican KMS is reachable from all nodes of the cluster.
configuration
Security keystore object reference.
_links
_links
name
string
Name of the configuration.
uuid
string
Keystore UUID.
state
Indicates whether or not the SVM key encryption key (KEK) is available cluster wide. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_state
boolean
Set to true when an SVM-KEK is present on all nodes of the cluster.
code
string
Code corresponding to the status message. Returns a 0 if the SVM-KEK is available on all nodes in the cluster.
message
string
Error message returned when there's no SVM-KEK availability on the cluster.
svm
_links
_links
name
string
uuid
string
barbican
_links
_links
application_cred_id
string
Keystone application credentials ID required to access the specified Barbican KMS.
configuration
configuration
enabled
boolean
Indicates whether the configuration is enabled.
key_id
string
Key Identifier URL of the Barbican KMS key encryption key. Must be an HTTPS URL.
keystone_url
string
Keystone URL for the access token. Must be an HTTPS URL.
proxy_host
string
Proxy host name.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
svm
svm
timeout
integer
Connection timeout in seconds.
uuid
string
A unique identifier of the Barbican KMS.
verify
boolean
Verify the identity of the Barbican KMS.
verify_host
boolean
Verify the identity of the Barbican KMS host name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
