Retrieve Barbican KMS configurations for all SVMs
Retrieves Barbican Key Management System (KMS) configurations for all Storage Virtual Machines (SVMs). This helps you manage and verify the encryption settings associated with your storage systems.
HTTP method and endpoint
GET /security/barbican-kms
Introduced in
ONTAP 9.17
Usage notes
Retrieves Barbican KMS configurations for all SVMs.
Related ONTAP commands
security key-manager external barbican show -
security key-manager external barbican check
scope |
string |
query |
False |
Filter by scope |
state.code |
string |
query |
False |
Filter by state.code |
state.message |
string |
query |
False |
Filter by state.message |
state.cluster_state |
boolean |
query |
False |
Filter by state.cluster_state |
proxy_type |
string |
query |
False |
Filter by proxy_type |
configuration.uuid |
string |
query |
False |
Filter by configuration.uuid |
configuration.name |
string |
query |
False |
Filter by configuration.name |
timeout |
integer |
query |
False |
Filter by timeout |
uuid |
string |
query |
False |
Filter by uuid |
key_id |
string |
query |
False |
Filter by key_id |
enabled |
boolean |
query |
False |
Filter by enabled |
verify |
boolean |
query |
False |
Filter by verify |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
proxy_port |
integer |
query |
False |
Filter by proxy_port |
application_cred_id |
string |
query |
False |
Filter by application_cred_id |
barbican_reachability.message |
string |
query |
False |
Filter by barbican_reachability.message |
barbican_reachability.reachable |
boolean |
query |
False |
Filter by barbican_reachability.reachable |
barbican_reachability.code |
string |
query |
False |
Filter by barbican_reachability.code |
proxy_username |
string |
query |
False |
Filter by proxy_username |
verify_host |
boolean |
query |
False |
Filter by verify_host |
proxy_host |
string |
query |
False |
Filter by proxy_host |
keystone_url |
string |
query |
False |
Filter by keystone_url |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[barbican] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"application_cred_id": "63e3cb77f84f42b7a0395a3efb7636f9",
"barbican_reachability": {
"code": "346758",
"message": "Barbican KMS is not reachable from all nodes - <reason>.",
"reachable": ""
"configuration": {
"name": "default",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"key_id": "https://172.29.58.184:9311/v1/secrets/5c610a4f-ea97-44b5-8682-f4daeafa9647",
"keystone_url": "https://keystoneip:5000/v3/auth/tokens",
"proxy_host": "proxy.eng.com",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"cluster_state": "",
"code": "346758",
"message": "Top-level internal key encryption key is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
"timeout": 60,
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65539801 |
The Barbican Key Management Service is unreachable from one or more nodes. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
Indicates whether the Barbican KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET request or an instance GET request unless it is explicitly requested using the field's query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns 0 if Barbican KMS is reachable from all nodes in the cluster. |
message |
string |
Set to the appropriate error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Barbican KMS is reachable from all nodes of the cluster. |
configuration
Security keystore object reference.
_links |
name |
string |
Name of the configuration. |
uuid |
string |
Keystore UUID. |
state
Indicates whether or not the SVM key encryption key (KEK) is available cluster wide.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_state |
boolean |
Set to true when an SVM-KEK is present on all nodes of the cluster. |
code |
string |
Code corresponding to the status message. Returns a 0 if the SVM-KEK is available on all nodes in the cluster. |
message |
string |
Error message returned when there's no SVM-KEK availability on the cluster. |
svm
_links |
name |
string |
uuid |
string |
barbican
_links |
string |
Keystone application credentials ID required to access the specified Barbican KMS. |
barbican_reachability |
Indicates whether the Barbican KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET request or an instance GET request unless it is explicitly requested using the field's query parameter or GET for all advanced properties is enabled. |
configuration |
Security keystore object reference. |
enabled |
boolean |
Indicates whether the configuration is enabled. |
key_id |
string |
Key Identifier URL of the Barbican KMS key encryption key. Must be an HTTPS URL. |
keystone_url |
string |
Keystone URL for the access token. Must be an HTTPS URL. |
proxy_host |
string |
Proxy host name. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
svm |
timeout |
integer |
Connection timeout in seconds. |
uuid |
string |
A unique identifier of the Barbican KMS. |
verify |
boolean |
Verify the identity of the Barbican KMS. |
verify_host |
boolean |
Verify the identity of the Barbican KMS host name. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
