REST API reference
Retrieve an external-role-mapping entry
Retrieves an external role mapping entry to review the mapping details between external roles and their corresponding ONTAP roles.
HTTP method and endpoint
GET /security/external-role-mappings/{external_role}/{provider}
Introduced in
ONTAP 9.16
Usage notes
Retrieves an external-role-mapping entry.
  • security login external-role-mapping show
external_role
string
path
True
External Identity provider role.
provider
string
path
True
Type of the external identity provider.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
comment
string
Any comment regarding this external-role-mapping entry.
external_role
string
ontap_role
ontap_role
ONTAP role to map with the external identity role.
  • Introduced in: 9.16
provider
string
timestamp
string
Date and time indicating when this external-role-mapping entry was created.
      "href": "/api/resourcelink"
  "comment": "string",
  "external_role": "string",
  "ontap_role": {
    "name": "admin"
  "provider": "string",
  "timestamp": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
ontap_role
_links
_links
name
string
Role name
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
