Retrieve an external-role-mapping entry
Retrieves an external role mapping entry to review the mapping details between external roles and their corresponding ONTAP roles.
HTTP method and endpoint
GET /security/external-role-mappings/{external_role}/{provider}
Introduced in
ONTAP 9.16
Usage notes
Retrieves an external-role-mapping entry.
Related ONTAP commands
security login external-role-mapping show
external_role |
string |
path |
True |
External Identity provider role. |
provider |
string |
path |
True |
Type of the external identity provider. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
Any comment regarding this external-role-mapping entry. |
external_role |
string |
ontap_role |
ONTAP role to map with the external identity role.
provider |
string |
timestamp |
string |
Date and time indicating when this external-role-mapping entry was created. |
"href": "/api/resourcelink"
"comment": "string",
"external_role": "string",
"ontap_role": {
"name": "admin"
"provider": "string",
"timestamp": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
ontap_role
_links |
name |
string |
Role name |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
