REST API reference
Retrieve a group-to-role mapping entry
Retrieves a group-to-role mapping entry to view the roles assigned to specific groups, helping manage security permissions efficiently.
HTTP method and endpoint
GET /security/group/role-mappings/{group_id}/{ontap_role.name}
Introduced in
ONTAP 9.16
Usage notes
Retrieves a group to role mapping entry.
  • security login group role-mapping show
group_id
integer
path
True
Group ID.
  • format: int64
  • Max value: 4294967295
  • Min value: 1
ontap_role.name
string
path
True
Role name.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
Any comment regarding this group entry.
group_id
integer
Group ID.
ontap_role
ontap_role
Role name.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
    "next": {
      "href": "/api/resourcelink"
  "comment": "string",
  "group_id": 1,
  "ontap_role": {
    "name": "admin"
  "scope": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ontap_role
Role name.
_links
_links
name
string
Role name
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
