REST API reference
Retrieve the JIT privilege user configurations for an SVM
Retrieves the JIT privilege user configurations for a specific SVM to understand the current privilege settings and manage access effectively.
HTTP method and endpoint
GET /security/jit-privilege-users
Introduced in
ONTAP 9.17
Usage notes
Retrieves the JIT privilege user configurations for an SVM.
  • security jit-privilege user show
start_time
string
query
False
Filter by start_time
end_time
string
query
False
Filter by end_time
account.name
string
query
False
Filter by account.name
session_validity
string
query
False
Filter by session_validity
comment
string
query
False
Filter by comment
application
string
query
False
Filter by application
owner.name
string
query
False
Filter by owner.name
owner.uuid
string
query
False
Filter by owner.uuid
jit_state
string
query
False
Filter by jit_state
role.name
string
query
False
Filter by role.name
jit_validity
string
query
False
Filter by jit_validity
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[security_jit_privilege_user]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "account": {
        "name": "joe.smith"
      "application": "string",
      "comment": "Comment text",
      "end_time": "2024-11-08 06:15:31 -0500",
      "jit_state": "active",
      "jit_validity": "P90D",
      "owner": {
        "name": "svm1",
      "role": {
        "name": "admin"
      "session_validity": "PT1H",
      "start_time": "2024-11-08 05:15:31 -0500"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
account_reference
The name of the user.
_links
_links
name
string
User account
owner
Owner name and UUID that uniquely identifies the JIT settings for a user.
_links
_links
name
string
uuid
string
role
The role the user will be elevated to.
_links
_links
name
string
Role name
account
account_reference
application
string
The name of the application.
comment
string
The description of the elevation rule.
end_time
string
The end date and time of the JIT privilege session in UTC.
jit_state
string
The current status of the rule: preactive, idle, or active.
jit_validity
string
The JIT validity period on this SVM for this user.
owner
owner
role
role
session_validity
string
The session validity period on this SVM for this user.
start_time
string
The start date and time of the JIT privilege session in UTC.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
