Retrieve the JIT privilege user configurations for an SVM
Retrieves JIT privilege user configurations for a specific SVM, which helps you manage and review user privileges in your storage environment.
HTTP method and endpoint
GET /security/jit-privilege-users
Introduced in
ONTAP 9.17
Usage notes
Retrieves the JIT privilege user configurations for an SVM.
Related ONTAP commands
security jit-privilege user show
account.name |
string |
query |
False |
Filter by account.name |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
comment |
string |
query |
False |
Filter by comment |
start_time |
string |
query |
False |
Filter by start_time |
session_validity |
string |
query |
False |
Filter by session_validity |
role.name |
string |
query |
False |
Filter by role.name |
jit_validity |
string |
query |
False |
Filter by jit_validity |
application |
string |
query |
False |
Filter by application |
jit_state |
string |
query |
False |
Filter by jit_state |
end_time |
string |
query |
False |
Filter by end_time |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[security_jit_privilege_user] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"account": {
"name": "joe.smith"
"application": "string",
"comment": "Comment text",
"end_time": "2024-11-08 11:15:31 +0000",
"jit_state": "active",
"jit_validity": "P90D",
"owner": {
"name": "svm1",
"role": {
"name": "admin"
"session_validity": "PT1H",
"start_time": "2024-11-08 10:15:31 +0000"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_reference
The name of the user.
_links |
name |
string |
User account |
owner
Owner name and UUID that uniquely identifies the JIT settings for a user.
_links |
name |
string |
uuid |
string |
role
The role the user will be elevated to.
_links |
name |
string |
Role name |
account |
The name of the user. |
application |
string |
The name of the application. |
comment |
string |
The description of the elevation rule. |
end_time |
string |
The end date and time of the JIT privilege session in UTC. |
jit_state |
string |
The current status of the rule: preactive, idle, or active. |
jit_validity |
string |
The JIT validity period on this SVM for this user. |
owner |
Owner name and UUID that uniquely identifies the JIT settings for a user. |
role |
The role the user will be elevated to. |
session_validity |
string |
The session validity period on this SVM for this user. |
start_time |
string |
The start date and time of the JIT privilege session in UTC. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
