Retrieve global JIT privilege configurations for an SVM
GET /security/jit-privileges
Introduced In: 9.17
Retrieves global JIT privilege configurations on an SVM.
Related ONTAP commands
security jit-privilege show
owner.name |
string |
query |
False |
Filter by owner.name |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
default_session_validity_period |
string |
query |
False |
Filter by default_session_validity_period |
application |
string |
query |
False |
Filter by application |
max_jit_validity_period |
string |
query |
False |
Filter by max_jit_validity_period |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[security_jit_privilege] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"application": "string",
"default_session_validity_period": "PT1H",
"max_jit_validity_period": "P90D",
"owner": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
Owner name and UUID that uniquely identifies the JIT privilege global settings.
_links |
name |
string |
uuid |
string |
_links |
application |
string |
The name of the application. |
string |
The default session validity period on this SVM. |
string |
The maximum JIT validity period allowed on this SVM. |
owner |
Owner name and UUID that uniquely identifies the JIT privilege global settings. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
