REST API reference
Retrieve global JIT privilege configurations for an SVM
GET /security/jit-privileges
Introduced In: 9.17
Retrieves global JIT privilege configurations on an SVM.
  • security jit-privilege show
max_jit_validity_period
string
query
False
Filter by max_jit_validity_period
default_session_validity_period
string
query
False
Filter by default_session_validity_period
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
application
string
query
False
Filter by application
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[security_jit_privilege]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "application": "string",
      "default_session_validity_period": "PT1H",
      "max_jit_validity_period": "P90D",
      "owner": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
Owner name and UUID that uniquely identifies the JIT privilege global settings.
_links
_links
name
string
uuid
string
_links
_links
application
string
The name of the application.
string
The default session validity period on this SVM.
string
The maximum JIT validity period allowed on this SVM.
owner
owner
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
