REST API reference
Retrieve a WebAuthn global setting entry
GET /security/webauthn/global-settings/{owner.uuid}
Introduced In: 9.16
Retrieves a WebAuthn global setting entry.
  • security webauthn show
owner.uuid
string
path
True
Used to identify a cluster or an SVM.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
attestation
string
Attestation conveyance type.
owner
svm_reference
require_rk
boolean
Specifies whether the resident key is required.
resident_key
string
Resident key.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
timeout
integer
The timeout interval for the WebAuthn request, in milliseconds.
user_verification
string
User verification.
      "href": "/api/resourcelink"
  "attestation": "none",
  "owner": {
    "name": "svm1",
  "require_rk": "",
  "resident_key": "discouraged",
  "scope": "string",
  "timeout": 600000,
  "user_verification": "discouraged"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
svm_reference
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
