REST API reference
Retrieve a shelf
Retrieves detailed information about a specific shelf, helping you manage and monitor your storage hardware effectively.
HTTP method and endpoint
GET /storage/shelves/{uid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific shelf.
  • storage shelf show
  • storage shelf port show
  • storage shelf drawer show
  • storage shelf drawer show-slot
  • storage shelf acp show
uid
string
path
True
Shelf UID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
acps
array[acps]
Alternate Control Paths to ACP processors/functions in shelf modules and expanders
bays
array[bays]
connection_type
string
current_sensors
array[current_sensors]
disk_count
integer
drawers
array[drawers]
errors
array[errors]
fans
array[fans]
frus
array[frus]
id
string
internal
boolean
local
boolean
location_led
string
manufacturer
manufacturer
model
string
module_type
string
name
string
paths
array[paths]
ports
array[ports]
raw_capacity
integer
Raw capacity of drives in shelf in 4k blocks
serial_number
string
state
string
temperature_sensors
array[temperature_sensors]
uid
string
vendor
vendor
voltage_sensors
array[voltage_sensors]
  "acps": [
      "address": "192.168.1.104",
      "channel": "out_of_band",
      "connection_state": "full_connectivity",
      "error": {
        "reason": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "message": "entry doesn't exist"
        "severity": "string",
        "type": "string"
      "netmask": "255.255.252.0",
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
      "port": "e0P",
      "subnet": "192.168.0.1"
  "bays": [
      "drawer": {
        "id": 1,
        "slot": 0
      "id": 0,
      "state": "ok",
      "type": "single_disk"
  "connection_type": "sas",
  "current_sensors": [
      "current": 14410,
      "id": 1,
      "installed": 1,
      "location": "rear of the shelf on the lower left power supply",
      "state": "ok"
  "disk_count": 12,
  "drawers": [
      "disk_count": 12,
      "error": "string",
      "part_number": "111-03071",
      "serial_number": "021604008263",
      "state": "ok"
  "errors": [
      "reason": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
  "fans": [
      "id": 1,
      "installed": 1,
      "rpm": 3020,
      "state": "ok"
  "frus": [
      "firmware_version": "0191",
      "installed": 1,
      "part_number": "111-00690+A2",
      "psu": {
        "crest_factor": 92,
        "model": "00",
        "power_drawn": 210,
        "power_rating": 1600
      "serial_number": "8000166294",
      "state": "error",
      "type": "module"
  "id": "1",
  "location_led": "off",
  "manufacturer": {
    "name": "NETAPP"
  "model": "DS2246",
  "module_type": "iom6",
  "name": "1.1",
  "paths": [
      "name": "2a",
      "node": {
        "name": "node1",
  "ports": [
      "cable": {
        "identifier": "500a0980000b6c3f-50000d1703544b80",
        "length": "2m",
        "part_number": "112-00431+A0",
        "serial_number": "616930439"
      "designator": "square",
      "id": 0,
      "mac_address": "string",
      "module_id": "a",
      "remote": {
        "chassis": "string",
        "device": "string",
        "phy": "12",
        "port": "string",
        "wwn": "50000D1703544B80"
      "speed": 100,
      "state": "connected",
      "wwn": "500A0980000B6C3F"
  "raw_capacity": 5157308772,
  "serial_number": "SHFMS1514000895",
  "state": "ok",
  "temperature_sensors": [
      "ambient": "",
      "id": 1,
      "installed": 1,
      "location": "temp sensor on midplane left",
      "state": "ok",
      "temperature": 32,
      "threshold": {
        "high": {
          "critical": 60,
          "warning": 55
        "low": {
          "critical": 0,
          "warning": 5
  "uid": "7777841915827391056",
  "vendor": {
    "manufacturer": "XYZ",
    "name": "XYZ",
    "part_number": "A92831142733",
    "product": "LS2246",
    "serial_number": "891234572210221"
  "voltage_sensors": [
      "id": 1,
      "installed": 1,
      "state": "ok",
      "voltage": 12.18
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
error
Error object is populated when connection_state becomes non-optimal
reason
error
severity
string
type
string
string
self
node
_links
_links
name
string
uuid
string
acps
address
string
channel
string
connection_state
string
enabled
boolean
error
error
netmask
string
node
node
port
string
subnet
string
drawer
id
integer
The drawer containing this bay
slot
integer
The drawer slot for this bay
bays
drawer
drawer
has_disk
boolean
id
integer
state
string
type
string
current_sensors
current
integer
Current, in milliamps
id
integer
installed
boolean
location
string
state
string
drawers
closed
boolean
disk_count
integer
error
string
id
integer
part_number
string
serial_number
string
state
string
errors
reason
error
fans
id
integer
installed
boolean
location
string
rpm
integer
state
string
psu
crest_factor
integer
The ratio of the peak voltage to the root-mean-square voltage
model
string
power_drawn
integer
Power drawn, in watts
power_rating
integer
Power rating, in watts
frus
firmware_version
string
id
integer
installed
boolean
part_number
string
psu
psu
serial_number
string
state
string
type
string
manufacturer
name
string
paths
Storage port
_links
_links
name
string
node
node
cable
identifier
string
length
string
part_number
string
serial_number
string
remote
chassis
string
device
string
mac_address
string
phy
string
port
string
wwn
string
ports
cable
cable
designator
string
id
integer
internal
boolean
mac_address
string
module_id
string
remote
remote
speed
integer
state
string
wwn
string
high
critical
integer
High critical threshold, in degrees Celsius
warning
integer
High warning threshold, in degrees Celsius
low
critical
integer
Low critical threshold, in degrees Celsius
warning
integer
Low warning threshold, in degrees Celsius
threshold
high
high
low
low
temperature_sensors
ambient
boolean
Sensor that measures the ambient temperature
id
integer
installed
boolean
location
string
state
string
temperature
integer
Temperature, in degrees Celsius
threshold
threshold
vendor
manufacturer
string
Support for this field will be removed in a future release. Please use vendor.name for this field.
name
string
part_number
string
Part number
product
string
Product name
serial_number
string
Serial number
voltage_sensors
id
integer
installed
boolean
location
string
state
string
voltage
number
Voltage, in volts
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
