REST API reference
Retrieve a shelf
Retrieves details about a specific shelf to examine its configuration and status within your storage environment.
HTTP method and endpoint
GET /storage/shelves/{uid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific shelf.
  • storage shelf show
  • storage shelf port show
  • storage shelf drawer show
uid
string
path
True
Shelf UID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
bays
array[bays]
connection_type
string
disk_count
integer
drawers
array[drawers]
errors
array[errors]
fans
array[fans]
frus
array[frus]
id
string
internal
boolean
local
boolean
model
string
module_type
string
name
string
paths
array[paths]
ports
array[ports]
serial_number
string
state
string
uid
string
vendor
vendor
  "bays": [
      "id": "0",
      "state": "ok",
      "type": "single_disk"
  "connection_type": "sas",
  "disk_count": "12",
  "drawers": [
      "disk_count": "12",
      "error": "string",
      "part_number": "111-03071",
      "serial_number": "021604008263",
      "state": "ok"
  "errors": [
      "reason": {
        "code": "string",
        "message": "string"
  "fans": [
      "id": "1",
      "location": "rear of the shelf on the lower left power supply",
      "rpm": "3020",
      "state": "ok"
  "frus": [
      "firmware_version": "0191",
      "part_number": "111-00690+A2",
      "serial_number": "8000166294",
      "state": "error",
      "type": "module"
  "id": "1",
  "model": "DS2246",
  "module_type": "iom6",
  "name": "1.1",
  "paths": [
          "href": "/api/resourcelink"
      "name": "2a",
      "node": {
        "name": "node1",
  "ports": [
      "cable": {
        "identifier": "500a0980000b6c3f-50000d1703544b80",
        "length": "2m",
        "part_number": "112-00431+A0",
        "serial_number": "616930439"
      "designator": "square",
      "id": "0",
      "mac_address": "string",
      "module_id": "a",
      "remote": {
        "chassis": "string",
        "device": "string",
        "phy": "12",
        "port": "string",
        "wwn": "50000D1703544B80"
      "state": "connected",
      "wwn": "500A0980000B6C3F"
  "serial_number": "SHFMS1514000895",
  "state": "ok",
  "uid": "7777841915827391056",
  "vendor": {
    "manufacturer": "XYZ",
    "part_number": "A92831142733",
    "product": "LS2246",
    "serial_number": "891234572210221"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
bays
has_disk
boolean
id
integer
state
string
type
string
drawers
closed
boolean
disk_count
integer
error
string
id
integer
part_number
string
serial_number
string
state
string
reason
code
string
Error code
message
string
Error message
errors
reason
reason
fans
id
integer
location
string
rpm
integer
state
string
frus
firmware_version
string
id
integer
part_number
string
serial_number
string
state
string
type
string
string
self
node
_links
_links
name
string
uuid
string
paths
Storage port
_links
_links
name
string
node
node
cable
identifier
string
length
string
part_number
string
serial_number
string
remote
chassis
string
device
string
mac_address
string
phy
string
port
string
wwn
string
ports
cable
cable
designator
string
id
integer
internal
boolean
mac_address
string
module_id
string
remote
remote
state
string
wwn
string
vendor
manufacturer
string
Manufacturer name
part_number
string
Part number
product
string
Product name
serial_number
string
Serial number
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
