REST API reference
Retrieve shelves
Retrieves a collection of storage shelves to view the configuration and status of your shelves.
HTTP method and endpoint
GET /storage/shelves
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of shelves.
  • storage shelf show
  • storage shelf port show
  • storage shelf drawer show
  • storage shelf drawer show-slot
  • storage shelf acp show
vendor.manufacturer
string
query
False
Filter by vendor.manufacturer
  • Introduced in: 9.8
vendor.name
string
query
False
Filter by vendor.name
  • Introduced in: 9.10
vendor.part_number
string
query
False
Filter by vendor.part_number
vendor.serial_number
string
query
False
Filter by vendor.serial_number
vendor.product
string
query
False
Filter by vendor.product
serial_number
string
query
False
Filter by serial_number
current_sensors.installed
boolean
query
False
Filter by current_sensors.installed
  • Introduced in: 9.13
current_sensors.id
integer
query
False
Filter by current_sensors.id
current_sensors.state
string
query
False
Filter by current_sensors.state
current_sensors.current
integer
query
False
Filter by current_sensors.current
current_sensors.location
string
query
False
Filter by current_sensors.location
state
string
query
False
Filter by state
uid
string
query
False
Filter by uid
connection_type
string
query
False
Filter by connection_type
id
string
query
False
Filter by id
drawers.serial_number
string
query
False
Filter by drawers.serial_number
drawers.part_number
string
query
False
Filter by drawers.part_number
drawers.error
string
query
False
Filter by drawers.error
drawers.disk_count
integer
query
False
Filter by drawers.disk_count
drawers.closed
boolean
query
False
Filter by drawers.closed
drawers.id
integer
query
False
Filter by drawers.id
drawers.state
string
query
False
Filter by drawers.state
acps.error.type
string
query
False
Filter by acps.error.type
acps.error.severity
string
query
False
Filter by acps.error.severity
acps.error.reason.arguments.code
string
query
False
Filter by acps.error.reason.arguments.code
acps.error.reason.arguments.message
string
query
False
Filter by acps.error.reason.arguments.message
acps.error.reason.message
string
query
False
Filter by acps.error.reason.message
acps.error.reason.code
string
query
False
Filter by acps.error.reason.code
acps.channel
string
query
False
Filter by acps.channel
acps.subnet
string
query
False
Filter by acps.subnet
acps.port
string
query
False
Filter by acps.port
acps.node.uuid
string
query
False
Filter by acps.node.uuid
acps.node.name
string
query
False
Filter by acps.node.name
acps.netmask
string
query
False
Filter by acps.netmask
acps.enabled
boolean
query
False
Filter by acps.enabled
acps.address
string
query
False
Filter by acps.address
acps.connection_state
string
query
False
Filter by acps.connection_state
ports.id
integer
query
False
Filter by ports.id
ports.mac_address
string
query
False
Filter by ports.mac_address
ports.module_id
string
query
False
Filter by ports.module_id
ports.cable.serial_number
string
query
False
Filter by ports.cable.serial_number
ports.cable.part_number
string
query
False
Filter by ports.cable.part_number
ports.cable.length
string
query
False
Filter by ports.cable.length
ports.cable.identifier
string
query
False
Filter by ports.cable.identifier
ports.designator
string
query
False
Filter by ports.designator
ports.wwn
string
query
False
Filter by ports.wwn
ports.internal
boolean
query
False
Filter by ports.internal
ports.state
string
query
False
Filter by ports.state
ports.remote.device
string
query
False
Filter by ports.remote.device
ports.remote.chassis
string
query
False
Filter by ports.remote.chassis
ports.remote.port
string
query
False
Filter by ports.remote.port
ports.remote.mac_address
string
query
False
Filter by ports.remote.mac_address
ports.remote.phy
string
query
False
Filter by ports.remote.phy
ports.remote.wwn
string
query
False
Filter by ports.remote.wwn
ports.speed
integer
query
False
Filter by ports.speed
  • Introduced in: 9.17
frus.state
string
query
False
Filter by frus.state
frus.installed
boolean
query
False
Filter by frus.installed
frus.type
string
query
False
Filter by frus.type
frus.firmware_version
string
query
False
Filter by frus.firmware_version
frus.serial_number
string
query
False
Filter by frus.serial_number
frus.part_number
string
query
False
Filter by frus.part_number
frus.id
integer
query
False
Filter by frus.id
frus.psu.crest_factor
integer
query
False
Filter by frus.psu.crest_factor
frus.psu.power_rating
integer
query
False
Filter by frus.psu.power_rating
frus.psu.model
string
query
False
Filter by frus.psu.model
frus.psu.power_drawn
integer
query
False
Filter by frus.psu.power_drawn
voltage_sensors.location
string
query
False
Filter by voltage_sensors.location
voltage_sensors.voltage
number
query
False
Filter by voltage_sensors.voltage
voltage_sensors.state
string
query
False
Filter by voltage_sensors.state
voltage_sensors.id
integer
query
False
Filter by voltage_sensors.id
voltage_sensors.installed
boolean
query
False
Filter by voltage_sensors.installed
name
string
query
False
Filter by name
paths.node.uuid
string
query
False
Filter by paths.node.uuid
paths.node.name
string
query
False
Filter by paths.node.name
paths.name
string
query
False
Filter by paths.name
temperature_sensors.location
string
query
False
Filter by temperature_sensors.location
temperature_sensors.state
string
query
False
Filter by temperature_sensors.state
temperature_sensors.id
integer
query
False
Filter by temperature_sensors.id
temperature_sensors.threshold.low.critical
integer
query
False
Filter by temperature_sensors.threshold.low.critical
temperature_sensors.threshold.low.warning
integer
query
False
Filter by temperature_sensors.threshold.low.warning
temperature_sensors.threshold.high.critical
integer
query
False
Filter by temperature_sensors.threshold.high.critical
temperature_sensors.threshold.high.warning
integer
query
False
Filter by temperature_sensors.threshold.high.warning
temperature_sensors.installed
boolean
query
False
Filter by temperature_sensors.installed
temperature_sensors.temperature
integer
query
False
Filter by temperature_sensors.temperature
temperature_sensors.ambient
boolean
query
False
Filter by temperature_sensors.ambient
disk_count
integer
query
False
Filter by disk_count
raw_capacity
integer
query
False
Filter by raw_capacity
errors.reason.arguments.code
string
query
False
Filter by errors.reason.arguments.code
errors.reason.arguments.message
string
query
False
Filter by errors.reason.arguments.message
errors.reason.message
string
query
False
Filter by errors.reason.message
  • Introduced in: 9.9
errors.reason.code
string
query
False
Filter by errors.reason.code
bays.has_disk
boolean
query
False
Filter by bays.has_disk
bays.drawer.id
integer
query
False
Filter by bays.drawer.id
  • Introduced in: 9.11
bays.drawer.slot
integer
query
False
Filter by bays.drawer.slot
bays.id
integer
query
False
Filter by bays.id
bays.type
string
query
False
Filter by bays.type
bays.state
string
query
False
Filter by bays.state
internal
boolean
query
False
Filter by internal
fans.installed
boolean
query
False
Filter by fans.installed
fans.id
integer
query
False
Filter by fans.id
fans.state
string
query
False
Filter by fans.state
fans.rpm
integer
query
False
Filter by fans.rpm
fans.location
string
query
False
Filter by fans.location
manufacturer.name
string
query
False
Filter by manufacturer.name
local
boolean
query
False
Filter by local
model
string
query
False
Filter by model
module_type
string
query
False
Filter by module_type
location_led
string
query
False
Filter by location_led
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[shelf]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "acps": [
          "address": "192.168.1.104",
          "channel": "out_of_band",
          "connection_state": "full_connectivity",
          "error": {
            "reason": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
              "message": "entry doesn't exist"
            "severity": "string",
            "type": "string"
          "netmask": "255.255.252.0",
          "node": {
            "name": "node1",
          "port": "e0P",
          "subnet": "192.168.0.1"
      "bays": [
          "drawer": {
            "id": 1,
            "slot": 0
          "id": 0,
          "state": "ok",
          "type": "single_disk"
      "connection_type": "sas",
      "current_sensors": [
          "current": 14410,
          "id": 1,
          "installed": 1,
          "location": "rear of the shelf on the lower left power supply",
          "state": "ok"
      "disk_count": 12,
      "drawers": [
          "disk_count": 12,
          "error": "string",
          "part_number": "111-03071",
          "serial_number": "021604008263",
          "state": "ok"
      "errors": [
          "reason": {
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
      "fans": [
          "id": 1,
          "installed": 1,
          "rpm": 3020,
          "state": "ok"
      "frus": [
          "firmware_version": "0191",
          "installed": 1,
          "part_number": "111-00690+A2",
          "psu": {
            "crest_factor": 92,
            "model": "00",
            "power_drawn": 210,
            "power_rating": 1600
          "serial_number": "8000166294",
          "state": "error",
          "type": "module"
      "id": "1",
      "location_led": "off",
      "manufacturer": {
        "name": "NETAPP"
      "model": "DS2246",
      "module_type": "iom6",
      "name": "1.1",
      "paths": [
          "name": "2a",
          "node": {
            "name": "node1",
      "ports": [
          "cable": {
            "identifier": "500a0980000b6c3f-50000d1703544b80",
            "length": "2m",
            "part_number": "112-00431+A0",
            "serial_number": "616930439"
          "designator": "square",
          "id": 0,
          "mac_address": "string",
          "module_id": "a",
          "remote": {
            "chassis": "string",
            "device": "string",
            "phy": "12",
            "port": "string",
            "wwn": "50000D1703544B80"
          "speed": 100,
          "state": "connected",
          "wwn": "500A0980000B6C3F"
      "raw_capacity": 5157308772,
      "serial_number": "SHFMS1514000895",
      "state": "ok",
      "temperature_sensors": [
          "ambient": "",
          "id": 1,
          "installed": 1,
          "location": "temp sensor on midplane left",
          "state": "ok",
          "temperature": 32,
          "threshold": {
            "high": {
              "critical": 60,
              "warning": 55
            "low": {
              "critical": 0,
              "warning": 5
      "uid": "7777841915827391056",
      "vendor": {
        "manufacturer": "XYZ",
        "name": "XYZ",
        "part_number": "A92831142733",
        "product": "LS2246",
        "serial_number": "891234572210221"
      "voltage_sensors": [
          "id": 1,
          "installed": 1,
          "state": "ok",
          "voltage": 12.18
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
error
Error object is populated when connection_state becomes non-optimal
reason
error
severity
string
type
string
self
node
_links
_links
name
string
uuid
string
acps
address
string
channel
string
connection_state
string
enabled
boolean
error
error
netmask
string
node
node
port
string
subnet
string
drawer
id
integer
The drawer containing this bay
slot
integer
The drawer slot for this bay
bays
drawer
drawer
has_disk
boolean
id
integer
state
string
type
string
current_sensors
current
integer
Current, in milliamps
id
integer
installed
boolean
location
string
state
string
drawers
closed
boolean
disk_count
integer
error
string
id
integer
part_number
string
serial_number
string
state
string
errors
reason
error
fans
id
integer
installed
boolean
location
string
rpm
integer
state
string
psu
crest_factor
integer
The ratio of the peak voltage to the root-mean-square voltage
model
string
power_drawn
integer
Power drawn, in watts
power_rating
integer
Power rating, in watts
frus
firmware_version
string
id
integer
installed
boolean
part_number
string
psu
psu
serial_number
string
state
string
type
string
manufacturer
name
string
paths
Storage port
_links
_links
name
string
node
node
cable
identifier
string
length
string
part_number
string
serial_number
string
remote
chassis
string
device
string
mac_address
string
phy
string
port
string
wwn
string
ports
cable
cable
designator
string
id
integer
internal
boolean
mac_address
string
module_id
string
remote
remote
speed
integer
state
string
wwn
string
high
critical
integer
High critical threshold, in degrees Celsius
warning
integer
High warning threshold, in degrees Celsius
low
critical
integer
Low critical threshold, in degrees Celsius
warning
integer
Low warning threshold, in degrees Celsius
threshold
high
high
low
low
temperature_sensors
ambient
boolean
Sensor that measures the ambient temperature
id
integer
installed
boolean
location
string
state
string
temperature
integer
Temperature, in degrees Celsius
threshold
threshold
vendor
manufacturer
string
Support for this field will be removed in a future release. Please use vendor.name for this field.
name
string
part_number
string
Part number
product
string
Product name
serial_number
string
Serial number
voltage_sensors
id
integer
installed
boolean
location
string
state
string
voltage
number
Voltage, in volts
shelf
acps
array[acps]
Alternate Control Paths to ACP processors/functions in shelf modules and expanders
bays
array[bays]
connection_type
string
current_sensors
array[current_sensors]
disk_count
integer
drawers
array[drawers]
errors
array[errors]
fans
array[fans]
frus
array[frus]
id
string
internal
boolean
local
boolean
location_led
string
manufacturer
manufacturer
model
string
module_type
string
name
string
paths
array[paths]
ports
array[ports]
raw_capacity
integer
Raw capacity of drives in shelf in 4k blocks
serial_number
string
state
string
temperature_sensors
array[temperature_sensors]
uid
string
vendor
vendor
voltage_sensors
array[voltage_sensors]
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
