REST API reference
Retrieve shelves
Retrieves information about all shelves in your storage environment, helping you monitor and manage shelf configurations effectively.
HTTP method and endpoint
GET /storage/shelves
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of shelves.
  • storage shelf show
  • storage shelf port show
  • storage shelf drawer show
uid
string
query
False
Filter by uid
paths.name
string
query
False
Filter by paths.name
paths.node.name
string
query
False
Filter by paths.node.name
paths.node.uuid
string
query
False
Filter by paths.node.uuid
disk_count
integer
query
False
Filter by disk_count
connection_type
string
query
False
Filter by connection_type
vendor.product
string
query
False
Filter by vendor.product
  • Introduced in: 9.8
vendor.part_number
string
query
False
Filter by vendor.part_number
vendor.manufacturer
string
query
False
Filter by vendor.manufacturer
vendor.serial_number
string
query
False
Filter by vendor.serial_number
errors.reason.code
string
query
False
Filter by errors.reason.code
  • Introduced in: 9.9
errors.reason.message
string
query
False
Filter by errors.reason.message
model
string
query
False
Filter by model
ports.internal
boolean
query
False
Filter by ports.internal
ports.mac_address
string
query
False
Filter by ports.mac_address
ports.designator
string
query
False
Filter by ports.designator
ports.state
string
query
False
Filter by ports.state
ports.remote.port
string
query
False
Filter by ports.remote.port
ports.remote.phy
string
query
False
Filter by ports.remote.phy
ports.remote.device
string
query
False
Filter by ports.remote.device
ports.remote.wwn
string
query
False
Filter by ports.remote.wwn
ports.remote.mac_address
string
query
False
Filter by ports.remote.mac_address
ports.remote.chassis
string
query
False
Filter by ports.remote.chassis
ports.id
integer
query
False
Filter by ports.id
ports.wwn
string
query
False
Filter by ports.wwn
ports.cable.identifier
string
query
False
Filter by ports.cable.identifier
ports.cable.serial_number
string
query
False
Filter by ports.cable.serial_number
ports.cable.part_number
string
query
False
Filter by ports.cable.part_number
ports.cable.length
string
query
False
Filter by ports.cable.length
ports.module_id
string
query
False
Filter by ports.module_id
bays.has_disk
boolean
query
False
Filter by bays.has_disk
bays.state
string
query
False
Filter by bays.state
bays.id
integer
query
False
Filter by bays.id
bays.type
string
query
False
Filter by bays.type
fans.location
string
query
False
Filter by fans.location
fans.state
string
query
False
Filter by fans.state
fans.rpm
integer
query
False
Filter by fans.rpm
fans.id
integer
query
False
Filter by fans.id
name
string
query
False
Filter by name
internal
boolean
query
False
Filter by internal
frus.serial_number
string
query
False
Filter by frus.serial_number
frus.state
string
query
False
Filter by frus.state
frus.part_number
string
query
False
Filter by frus.part_number
frus.type
string
query
False
Filter by frus.type
frus.id
integer
query
False
Filter by frus.id
frus.firmware_version
string
query
False
Filter by frus.firmware_version
module_type
string
query
False
Filter by module_type
local
boolean
query
False
Filter by local
drawers.closed
boolean
query
False
Filter by drawers.closed
drawers.error
string
query
False
Filter by drawers.error
drawers.part_number
string
query
False
Filter by drawers.part_number
drawers.id
integer
query
False
Filter by drawers.id
drawers.disk_count
integer
query
False
Filter by drawers.disk_count
drawers.serial_number
string
query
False
Filter by drawers.serial_number
drawers.state
string
query
False
Filter by drawers.state
id
string
query
False
Filter by id
state
string
query
False
Filter by state
serial_number
string
query
False
Filter by serial_number
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[shelf]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "bays": [
          "id": "0",
          "state": "ok",
          "type": "single_disk"
      "connection_type": "sas",
      "disk_count": "12",
      "drawers": [
          "disk_count": "12",
          "error": "string",
          "part_number": "111-03071",
          "serial_number": "021604008263",
          "state": "ok"
      "errors": [
          "reason": {
            "code": "string",
            "message": "string"
      "fans": [
          "id": "1",
          "location": "rear of the shelf on the lower left power supply",
          "rpm": "3020",
          "state": "ok"
      "frus": [
          "firmware_version": "0191",
          "part_number": "111-00690+A2",
          "serial_number": "8000166294",
          "state": "error",
          "type": "module"
      "id": "1",
      "model": "DS2246",
      "module_type": "iom6",
      "name": "1.1",
      "paths": [
          "name": "2a",
          "node": {
            "name": "node1",
      "ports": [
          "cable": {
            "identifier": "500a0980000b6c3f-50000d1703544b80",
            "length": "2m",
            "part_number": "112-00431+A0",
            "serial_number": "616930439"
          "designator": "square",
          "id": "0",
          "mac_address": "string",
          "module_id": "a",
          "remote": {
            "chassis": "string",
            "device": "string",
            "phy": "12",
            "port": "string",
            "wwn": "50000D1703544B80"
          "state": "connected",
          "wwn": "500A0980000B6C3F"
      "serial_number": "SHFMS1514000895",
      "state": "ok",
      "uid": "7777841915827391056",
      "vendor": {
        "manufacturer": "XYZ",
        "part_number": "A92831142733",
        "product": "LS2246",
        "serial_number": "891234572210221"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
bays
has_disk
boolean
id
integer
state
string
type
string
drawers
closed
boolean
disk_count
integer
error
string
id
integer
part_number
string
serial_number
string
state
string
reason
code
string
Error code
message
string
Error message
errors
reason
reason
fans
id
integer
location
string
rpm
integer
state
string
frus
firmware_version
string
id
integer
part_number
string
serial_number
string
state
string
type
string
self
node
_links
_links
name
string
uuid
string
paths
Storage port
_links
_links
name
string
node
node
cable
identifier
string
length
string
part_number
string
serial_number
string
remote
chassis
string
device
string
mac_address
string
phy
string
port
string
wwn
string
ports
cable
cable
designator
string
id
integer
internal
boolean
mac_address
string
module_id
string
remote
remote
state
string
wwn
string
vendor
manufacturer
string
Manufacturer name
part_number
string
Part number
product
string
Product name
serial_number
string
Serial number
shelf
bays
array[bays]
connection_type
string
disk_count
integer
drawers
array[drawers]
errors
array[errors]
fans
array[fans]
frus
array[frus]
id
string
internal
boolean
local
boolean
model
string
module_type
string
name
string
paths
array[paths]
ports
array[ports]
serial_number
string
state
string
uid
string
vendor
vendor
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
