REST API reference
Retrieve the EMS role-based configuration for an access control role
Retrieves the EMS role-based configuration for an access control role, which provides the current settings and permissions associated with that role.
HTTP method and endpoint
GET /support/ems/role-configs/{access_control_role.name}
Introduced in
ONTAP 9.13
Usage notes
Retrieves the EMS role-based configuration of the access control role.
  • event role-config show
string
path
True
Access control role name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
access_control_role
access_control_role
Access control role that the event filter is assigned to.
event_filter
event_filter
Event filter that is assigned to the access control role.
limit_access_to_global_configs
boolean
Indicates whether the access control has limited access to global EMS configurations.
      "href": "/api/resourcelink"
  "access_control_role": {
    "name": "admin"
  "event_filter": {
    "name": "important-events"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
access_control_role
_links
_links
name
string
Role name
event_filter
_links
_links
name
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
