Retrieve the EMS role-based configuration for an access control role
Retrieves the EMS role-based configuration for an access control role, which provides the current settings and permissions associated with that role.
HTTP method and endpoint
GET /support/ems/role-configs/{access_control_role.name}
Introduced in
ONTAP 9.13
Usage notes
Retrieves the EMS role-based configuration of the access control role.
Related ONTAP commands
event role-config show
access_control_role.name |
string |
path |
True |
Access control role name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
access_control_role |
Access control role that the event filter is assigned to. |
event_filter |
Event filter that is assigned to the access control role. |
limit_access_to_global_configs |
boolean |
Indicates whether the access control has limited access to global EMS configurations. |
"href": "/api/resourcelink"
"access_control_role": {
"name": "admin"
"event_filter": {
"name": "important-events"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
access_control_role
_links |
name |
string |
Role name |
event_filter
_links |
name |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
