REST API reference
Manage configuration backups
Create, delete, and retrieve configuration backup files to manage your ONTAP system's resilience. Use these endpoints to generate backups on demand, ensuring you have the necessary configuration data for both individual nodes and the entire cluster.
Overview
This API supports creating, deleting and retrieving configuration backup files. Configuration backups can be 'cluster' or 'node' type. A 'cluster' backup contains cluster-wide configuration in addition to the configuration of each node in the cluster. A 'node' backup contains only node-specific configuration such as configuration files on the root volume and the boot variables. For creating a cluster backup, a cluster-wide job is queued. For creating a node backup, a private job local to the node is queued. In addition to the backups created using this API, ONTAP creates configuration backups automatically based on job schedules. This API supports creating configuration backups on demand only. It supports deleting and retrieving configuration backups that are created automatically or on demand. For information on configuration backup settings for automatically created backups, see DOC /support/configuration-backup
Retrieving a list of configuration backup files
# The API:
/api/support/configuration-backup/backups
# The call:
curl -X GET "https://<mgmt-ip>/api/support/configuration-backup/backups" -H "accept: application/hal+json"
# The response:
"records": [
    "node": {
      "uuid": "5cafe0f6-499f-11e9-b644-005056bbcf93",
      "name": "node1",
          "href": "/api/cluster/nodes/5cafe0f6-499f-11e9-b644-005056bbcf93"
    "name": "backup1.7z",
        "href": "/api/support/configuration-backup/backups/5cafe0f6-499f-11e9-b644-005056bbcf93/backup1.7z"
"num_records": 1,
    "href": "/api/support/configuration-backup/backups"
Retrieving details of the specified configuration backup file
# The API:
/api/support/configuration-backup/backups/{node.uuid}/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/configuration-backup/backups/bc2f15d0-8b93-11e9-90e9-005056bb6a30/backup1.7z" -H "accept: application/hal+json"
# The response:
"node": {
  "uuid": "bc2f15d0-8b93-11e9-90e9-005056bb6a30",
  "name": "node1",
      "href": "/api/cluster/nodes/bc2f15d0-8b93-11e9-90e9-005056bb6a30"
"type": "cluster",
"time": "2019-06-10T13:35:06-04:00",
"size": 6058408,
"backup_nodes": [
    "name": "node1"
    "name": "node2"
"version": "9.7.0",
"auto": false,
"download_link": "https://10.224.66.113/backups/backup1.7z",
    "href": "/api/support/configuration-backup/backups/bc2f15d0-8b93-11e9-90e9-005056bb6a30/backup1.7z"
Creating a configuration backup file
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/support/configuration-backup/backups" -H "accept: application/hal+json" -d "@create_backup.txt"
create_backup.txt:
"node":
    "uuid": "ac13c636-4fc9-11e9-94c2-005056bb2516",
    "name": "node1"
"name": "backup3.7z"
# The response header:
HTTP/1.1 202 Accepted
Date: Tue, 26 Mar 2019 14:26:24 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/support/configuration-backup/backups/ac13c636-4fc9-11e9-94c2-005056bb2516/backup3.7z
Content-Length: 189
Content-Type: application/hal+json
"job": {
  "uuid": "22acfb68-4fd3-11e9-94c2-005056bb2516",
      "href": "/api/cluster/jobs/22acfb68-4fd3-11e9-94c2-005056bb2516"
Deleting a configuration backup file
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/configuration-backup/backups/5cafe0f6-499f-11e9-b644-005056bbcf93/backup1.7z" -H "content-type: application/json"
HTTP/1.1 200 OK
Date: Tue, 26 Mar 2019 14:32:23 GMT
Content-Length: 3
