REST API reference
Modify the mediator configuration
PATCH /cluster/mediators/{uuid}
Introduced In: 9.17
Modifies the mediator configuration.
uuid
string
path
True
  • format: uuid
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
dr_group
dr_group
DR group reference.
local_mediator_connectivity
string
Indicates the mediator connectivity status of the local cluster. Possible values are connected, unreachable, unusable and down-high-latency. This field is only applicable to the mediators in SnapMirror active sync configuration.
peer_mediator_connectivity
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown and down-high-latency.
reachable
boolean
Indicates the connectivity status of the mediator.
strict_cert_validation
boolean
Indicates if strict validation of certificates is performed while making REST API calls to the mediator. This field is only applicable to the ONTAP Cloud Mediator.
  • Default value: 1
  • example: true
  • Introduced in: 9.17
  • x-nullable: true
use_http_proxy_local
boolean
Indicates if the local cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
  • Default value: 1
  • example: true
  • x-nullable: true
use_http_proxy_remote
boolean
Indicates if the remote cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
  • Default value: 1
  • example: true
  • writeOnly: 1
  • x-nullable: true
uuid
string
The unique identifier for the mediator service.
Example request
  "dr_group": {
    "id": 0
  "local_mediator_connectivity": "connected",
  "peer_mediator_connectivity": "connected",
  "reachable": 1,
  "strict_cert_validation": 1,
  "use_http_proxy_local": 1,
  "use_http_proxy_remote": 1,
  "uuid": "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response codes
Error code Description
13369377
Mediator field "mediator.id" does not exist.
13369412
Modification of the mediator configuration succeeded on the peer cluster but failed on the local cluster. Reason : {Reason of failure}. Wait a few minutes, then try the operation again.
13369421
Failed to modify mediator configuration on the cluster. Reason : {Reason of failure}. Wait a few minutes, then try the operation again.
dr_group
DR group reference.
id
integer
DR Group ID
string
peer_cluster
The peer cluster that the mediator service is used for.
name
string
uuid
string
mediator
Mediator information
dr_group
dr_group
DR group reference.
string
string
reachable
boolean
boolean
  • Default value: 1
  • example: true
  • x-nullable: true
boolean
  • Default value: 1
  • example: true
  • x-nullable: true
boolean
  • Default value: 1
  • example: true
  • writeOnly: 1
  • x-nullable: true
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
