Modify the mediator configuration
PATCH /cluster/mediators/{uuid}
Introduced In: 9.17
Modifies the mediator configuration.
uuid |
string |
path |
True |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
dr_group |
DR group reference. |
local_mediator_connectivity |
string |
Indicates the mediator connectivity status of the local cluster. Possible values are connected, unreachable, unusable and down-high-latency. This field is only applicable to the mediators in SnapMirror active sync configuration. |
peer_mediator_connectivity |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown and down-high-latency. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
strict_cert_validation |
boolean |
Indicates if strict validation of certificates is performed while making REST API calls to the mediator. This field is only applicable to the ONTAP Cloud Mediator.
use_http_proxy_local |
boolean |
Indicates if the local cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
use_http_proxy_remote |
boolean |
Indicates if the remote cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
uuid |
string |
The unique identifier for the mediator service. |
Example request
"dr_group": {
"id": 0
"local_mediator_connectivity": "connected",
"peer_mediator_connectivity": "connected",
"reachable": 1,
"strict_cert_validation": 1,
"use_http_proxy_local": 1,
"use_http_proxy_remote": 1,
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response codes
| Error code | Description |
13369377 |
Mediator field "mediator.id" does not exist. |
13369412 |
Modification of the mediator configuration succeeded on the peer cluster but failed on the local cluster. Reason : {Reason of failure}. Wait a few minutes, then try the operation again. |
13369421 |
Failed to modify mediator configuration on the cluster. Reason : {Reason of failure}. Wait a few minutes, then try the operation again. |
dr_group
DR group reference.
id |
integer |
DR Group ID |
href |
string |
_links
peer_cluster
The peer cluster that the mediator service is used for.
name |
string |
uuid |
string |
mediator
Mediator information
dr_group |
string |
string |
reachable |
boolean |
boolean |
boolean |
boolean |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
