REST API reference
Update Kerberos realm properties
Updates the properties of a Kerberos realm to manage authentication settings for your network services.
HTTP method and endpoint
PATCH /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
  • vserver nfs kerberos realm modify
svm.uuid
string
path
True
SVM UUID
name
string
path
True
Kerberos realm
Request Body
Name Type Description
ad_server
ad_server
admin_server
admin_server
clock_skew
integer
Specifies the allowed time of clock-skew between the server and clients, in minutes.
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
password_server
password_server
svm
svm
Example request
  "ad_server": {
    "address": "1.2.3.4",
    "name": "string"
  "admin_server": {
  "comment": "string",
  "encryption_types": [
    "string"
  "kdc": {
    "ip": "1.2.3.4",
    "port": 88,
    "vendor": "string"
  "name": "string",
  "password_server": {
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes Description
1966125
Failed to remove hosts entry.
1966126
Failed to lookup hosts entry.
1966131
Failed to create hosts entry.
1966132
Failed to modify hosts entry.
2949121
Active Directory server name required.
2949122
Active Directory server address required
2949123
Failed to create Kerberos realm.
2949124
Failed to create hosts file entry.
2949141
Failed to lookup Kerberos realm.
2949148
Failed to modify Kerberos realm.
3276976
"realm" is a required input
3276998
Only the data Vservers can own NFS Kerberos realms.
string
ad_server
address
string
Active Directory server IP address
name
string
admin_server
address
string
Admin server IP address.
port
integer
Specifies the port number of admin server.
kdc
ip
string
KDC IP address
port
integer
KDC port
vendor
string
Key Distribution Center (KDC) vendor. Following values are supported:
  • microsoft - Microsoft Active Directory KDC
  • other - MIT Kerberos KDC or other KDC
password_server
address
string
Password server IP address.
port
integer
Specifies the port number of password server.
svm
name
string
uuid
string
kerberos_realm
ad_server
ad_server
admin_server
admin_server
clock_skew
integer
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
password_server
password_server
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
