REST API reference
Updates the properties of a kerberos realm
  • [doc /protocols/nfs/kerberos/realms](#docs-nas-protocols_nfs_kerberos_realms)
PATCH /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Introduced In: 9.6
Updates the properties of a Kerberos realm.
  • vserver nfs kerberos realm modify
svm.uuid
string
path
True
SVM UUID
name
string
path
True
Kerberos realm
Request Body
Name Type Description
ad_server
ad_server
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
svm
svm
Example request
  "ad_server": {
    "address": "1.2.3.4",
    "name": "string"
  "comment": "string",
  "encryption_types": [
    "string"
  "kdc": {
    "ip": "1.2.3.4",
    "port": "88",
    "vendor": "string"
  "name": "string",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes Description
1966125
Failed to remove hosts entry.
1966126
Failed to lookup hosts entry.
1966131
Failed to create hosts entry.
1966132
Failed to modify hosts entry.
2949121
Active Directory server name required.
2949122
Active Directory server address required
2949123
Failed to create Kerberos realm.
2949124
Failed to create hosts file entry.
2949141
Failed to lookup Kerberos realm.
2949148
Failed to modify Kerberos realm.
3276976
"realm" is a required input
3276998
Only the data Vservers can own NFS Kerberos realms.
string
ad_server
address
string
Active Directory server IP address
name
string
kdc
ip
string
KDC IP address
port
integer
KDC port
vendor
string
Key Distribution Center (KDC) vendor. Following values are suported:
  • microsoft - Microsoft Active Directory KDC
  • other - MIT Kerberos KDC or other KDC
svm
name
string
The name of the SVM.
uuid
string
kerberos_realm
ad_server
ad_server
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
