Update an NVMe subsystem host
Updates an NVMe subsystem host to modify its configuration or properties as needed for your storage environment.
HTTP method and endpoint
PATCH /protocols/nvme/subsystems/{subsystem.uuid}/hosts/{nqn}
Introduced in
ONTAP 9.17
Related ONTAP commands
vserver nvme subsystem host add-proximal-vserver -
vserver nvme subsystem host remove-proximal-vserver
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
nqn |
string |
path |
True |
The NVMe qualified name (NQN) used to identify the NVMe subsystem host. |
Request Body
| Name | Type | Description |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
proximity |
Properties that define the SVMs to which the host is proximal. This information is used to properly report active optimized and active non-optimized network paths using an NVMe controller. If no configuration has been specified for the host, the sub-object is not present in GET requests. These properties apply to all instances of the host in the NVMe subsystem in the SVM and its peers. |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
Example request
"io_queue": {
"count": 4,
"depth": 32
"proximity": {
"peer_svms": [
"name": "peer1",
"uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
"subsystem": {
"name": "subsystem1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5376354 |
The SVM peer relationship does not exist. |
26345675 |
The SVM peer relationship contains local SVM name mismatch. |
72090001 |
The NVMe subsystem does not exist. |
href |
string |
_links
dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
mode |
string |
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
io_queue
count |
integer |
The number of I/O queue pairs. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue count is being used. Valid in GET only. |
depth |
integer |
The I/O queue depth. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue depth is being used. Valid in GET only. |
peer_svms
A reference to an SVM peer relationship.
name |
string |
The local name of the peer SVM. This name is unique among all local and peer SVMs. |
uuid |
string |
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself. |
proximity
local_svm |
boolean |
A boolean that indicates if the host is proximal to the SVM for which it is configured. |
peer_svms |
array[peer_svms] |
An array of remote peer SVMs to which the host is proximal. |
io_queue
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
io_queue |
subsystem |
nvme_subsystem_host
io_queue |
proximity |
subsystem |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
