REST API reference
Update an NVMe subsystem host
Updates an NVMe subsystem host to modify its configuration or properties as needed for your storage environment.
HTTP method and endpoint
PATCH /protocols/nvme/subsystems/{subsystem.uuid}/hosts/{nqn}
Introduced in
ONTAP 9.17
  • vserver nvme subsystem host add-proximal-vserver
  • vserver nvme subsystem host remove-proximal-vserver
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
nqn
string
path
True
The NVMe qualified name (NQN) used to identify the NVMe subsystem host.
Request Body
Name Type Description
io_queue
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
proximity
proximity
Properties that define the SVMs to which the host is proximal. This information is used to properly report active optimized and active non-optimized network paths using an NVMe controller. If no configuration has been specified for the host, the sub-object is not present in GET requests.
These properties apply to all instances of the host in the NVMe subsystem in the SVM and its peers.
subsystem
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
Example request
  "io_queue": {
    "count": 4,
    "depth": 32
  "proximity": {
    "peer_svms": [
        "name": "peer1",
        "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
  "subsystem": {
    "name": "subsystem1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5376354
The SVM peer relationship does not exist.
26345675
The SVM peer relationship contains local SVM name mismatch.
72090001
The NVMe subsystem does not exist.
string
dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
io_queue
count
integer
The number of I/O queue pairs. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue count is being used. Valid in GET only.
depth
integer
The I/O queue depth. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue depth is being used. Valid in GET only.
peer_svms
A reference to an SVM peer relationship.
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
local_svm
boolean
A boolean that indicates if the host is proximal to the SVM for which it is configured.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the host is proximal.
io_queue
count
integer
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem.
depth
integer
The I/O queue depth. The default value is inherited from the owning NVMe subsystem.
subsystem
name
string
The name of the NVMe subsystem.
uuid
string
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
io_queue
io_queue
subsystem
subsystem
nvme_subsystem_host
io_queue
io_queue
proximity
proximity
subsystem
subsystem
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
