REST API reference
Update an external-role-mapping entry
PATCH /security/external-role-mappings/{external_role}/{provider}
Introduced In: 9.16
Updates an external-role-mapping entry.
  • security login external-role-mapping modify
external_role
string
path
True
External Identity provider role.
provider
string
path
True
Type of the external identity provider.
fields
array[string]
query
False
Specify the fields to return.
Request Body
Name Type Description
comment
string
Any comment regarding this external-role-mapping entry.
ontap_role
ontap_role
ONTAP role to map with the external identity role.
  • Introduced in: 9.16
timestamp
string
Date and time indicating when this external-role-mapping entry was created.
Example request
  "comment": "string",
  "ontap_role": {
    "name": "admin"
  "timestamp": "string"
Status: 200, Ok
comment
string
ontap_role
ontap_role
timestamp
string
  "ontap_role": {
    "name": "admin"
Status: Default
ONTAP Error Response Codes
Error Code Description
5636243
Provided ONTAP role is not configured.
string
ontap_role
name
string
Role name
security_external_role_mapping
comment
string
ontap_role
ontap_role
timestamp
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
