Update an external-role-mapping entry
Updates an external role mapping entry, modifying the mappings for external authentication services as needed.
HTTP method and endpoint
PATCH /security/external-role-mappings/{external_role}/{provider}
Introduced in
ONTAP 9.16
Usage notes
Updates an external-role-mapping entry.
Related ONTAP commands
security login external-role-mapping modify
external_role |
string |
path |
True |
External Identity provider role. |
provider |
string |
path |
True |
Type of the external identity provider. |
fields |
array[string] |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Any comment regarding this external-role-mapping entry. |
ontap_role |
ONTAP role to map with the external identity role.
timestamp |
string |
Date and time indicating when this external-role-mapping entry was created. |
Example request
"comment": "string",
"ontap_role": {
"name": "admin"
"timestamp": "string"
Status: 200, Ok
comment |
string |
ontap_role |
timestamp |
string |
"ontap_role": {
"name": "admin"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636243 |
Provided ONTAP role is not configured. |
href |
string |
self_link
_links
ontap_role
name |
string |
Role name |
security_external_role_mapping
comment |
string |
ontap_role |
timestamp |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
