REST API reference
Modify JIT privilege configurations for an SVM
PATCH /security/jit-privileges/{owner.uuid}/{application}
Introduced In: 9.17
Modifies the JIT privilege configurations for an SVM.
  • security jit-privilege modify
owner.uuid
string
path
True
Used to identify a cluster or an SVM.
application
string
path
True
Application name.
Request Body
Name Type Description
default_session_validity_period
string
The default session validity period on this SVM.
max_jit_validity_period
string
The maximum JIT validity period allowed on this SVM.
Example request
  "default_session_validity_period": "PT1H",
  "max_jit_validity_period": "P90D"
Status: 200, Ok
string
string
Status: Default, Error
string
owner
Owner name and UUID that uniquely identifies the JIT privilege global settings.
name
string
uuid
string
security_jit_privilege
string
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
