Modify JIT privilege configurations for an SVM
Modifies the JIT privilege configurations for an SVM to update its security settings or access controls.
HTTP method and endpoint
PATCH /security/jit-privileges/{owner.uuid}/{application}
Introduced in
ONTAP 9.17
Related ONTAP commands
security jit-privilege modify
owner.uuid |
string |
path |
True |
Used to identify a cluster or an SVM. |
application |
string |
path |
True |
Application name. |
Request Body
| Name | Type | Description |
default_session_validity_period |
string |
The default session validity period on this SVM. |
max_jit_validity_period |
string |
The maximum JIT validity period allowed on this SVM. |
Example request
"default_session_validity_period": "PT1H",
"max_jit_validity_period": "P90D"
Status: 200, Ok
string |
string |
Status: Default, Error
href |
string |
_links
owner
Owner name and UUID that uniquely identifies the JIT privilege global settings.
name |
string |
uuid |
string |
security_jit_privilege
string |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
