Create the SAML default metadata configuration
Creates the SAML default metadata configuration, managing identity provider settings for authentication workflows.
HTTP method and endpoint
POST /security/authentication/cluster/saml-sp/default-metadata
Introduced in
ONTAP 9.17
Usage notes
Note that common_name is mutually exclusive with serial_number and ca in POST requests.
Optional properties
certificate -
host
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
certificate |
host |
string |
The SAML service provider host. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
Example request
"certificate": {
"ca": "string",
"common_name": "cluster1",
"serial_number": "1506B24A94F566BA"
"host": "string",
"scope": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320794 |
Invalid host parameter for default metadata generation. The host parameter must be the cluster management interface's IP address. If the cluster management interface is not available, the node management interface's IP address must be used. |
12320805 |
The certificate information provided does not match any installed certificates. |
12320806 |
The certificate information entered does not match any installed certificates. |
12320820 |
No certificate is installed with the specified |
12320821 |
12320825 |
SAML configuration already exists. Cannot create the metadata when SAML configuration is already present. |
12320831 |
Default metadata configuration already exists. |
href |
string |
_links
certificate
ca |
string |
Server certificate issuing certificate authority (CA). This cannot be used with the server certificate common name. |
common_name |
string |
Server certificate common name. This cannot be used with the certificate authority (CA) or serial_number. |
serial_number |
string |
Server certificate serial number. This cannot be used with the server certificate common name. |
security_saml_def_metadata
certificate |
host |
string |
scope |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
