REST API reference
Create the SAML default metadata configuration
Creates the SAML default metadata configuration, managing identity provider settings for authentication workflows.
HTTP method and endpoint
POST /security/authentication/cluster/saml-sp/default-metadata
Introduced in
ONTAP 9.17
Usage notes
Note that common_name is mutually exclusive with serial_number and ca in POST requests.
Optional properties
  • certificate
  • host
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
certificate
certificate
host
string
The SAML service provider host.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "certificate": {
    "ca": "string",
    "common_name": "cluster1",
    "serial_number": "1506B24A94F566BA"
  "host": "string",
  "scope": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
12320794
Invalid host parameter for default metadata generation. The host parameter must be the cluster management interface's IP address. If the cluster management interface is not available, the node management interface's IP address must be used.
12320805
The certificate information provided does not match any installed certificates.
12320806
The certificate information entered does not match any installed certificates.
12320820
No certificate is installed with the specified certificate.ca and certificate.serial.
12320821
No certificate is installed with the specified certificate.common_name.
12320825
SAML configuration already exists. Cannot create the metadata when SAML configuration is already present.
12320831
Default metadata configuration already exists.
string
certificate
ca
string
Server certificate issuing certificate authority (CA). This cannot be used with the server certificate common name.
common_name
string
Server certificate common name. This cannot be used with the certificate authority (CA) or serial_number.
serial_number
string
Server certificate serial number. This cannot be used with the server certificate common name.
security_saml_def_metadata
certificate
certificate
host
string
scope
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
