REST API reference
Rekey the internal key in the key hierarchy for an SVM with a Barbican KMS configuration
POST /security/barbican-kms/{uuid}/rekey-internal
Introduced In: 9.17
Rekeys the internal key in the key hierarchy for an SVM with a Barbican KMS configuration.
  • security key-manager external barbican rekey-internal
uuid
string
path
True
UUID of the existing Barbican KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
65536205
Internal error. Failed to generate SVM key in the kernel.
65536882
Internal error. UUID is missing.
65536883
Internal error. Volume encryption key is missing.
65536884
Internal error. Volume encryption key is invalid.
65536889
Internal error. Volume has invalid encryption blob.
65536973
Internal error. Volume DSID is missing.
65537533
Internal error. Failed to unwrap SVM key encryption key.
65537547
One or more volume encryption keys (VEKs) for this data SVM's encrypted volumes are stored in the key manager configured for the admin SVM. Use the REST API POST method "/api/security/key-managers/{source.svm.uuid}/migrate" to migrate these keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
65537556
ONTAP is unable to encrypt or decrypt because the configured external key manager is in a blocked state. Possible reasons for a blocked state include the top-level external key protection key is not found, disabled or has insufficient privileges. Resolve the external key manager key issues at the key manager's portal before running the rekey operation.
65537565
Internal error. Failed to update the VDEK blob.
65537610
Rekey cannot be performed while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent rekeying. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to re-run and complete the operation.
65539200
The key custodian not provided with an external key value store.
65539201
Failed to encrypt.
65539202
Failed to decrypt.
65539416
Internal error. Failed to parse the key value store response.
65539436
Rekey cannot be performed while the enabled keystore configuration is being initialized. Wait until the keystore is in the active state, and rerun the rekey operation.
65539437
Rekey cannot be performed while the enabled keystore configuration is being disabled.
65539817
The Barbican Key Management Service is not configured.
65539834
New Key ID not found.
65539836
No Key Management Service configured.
65539844
Failed to import the SVM-KEK.
196608088
Internal error. Failed to get encryption operation status.
196608352
Internal error. The encryption blob was not found in the RDB table.
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
