Rekey the internal key in the key hierarchy for an SVM with a Barbican KMS configuration
POST /security/barbican-kms/{uuid}/rekey-internal
Introduced In: 9.17
Rekeys the internal key in the key hierarchy for an SVM with a Barbican KMS configuration.
Related ONTAP commands
security key-manager external barbican rekey-internal
uuid |
string |
path |
True |
UUID of the existing Barbican KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536205 |
Internal error. Failed to generate SVM key in the kernel. |
65536882 |
Internal error. UUID is missing. |
65536883 |
Internal error. Volume encryption key is missing. |
65536884 |
Internal error. Volume encryption key is invalid. |
65536889 |
Internal error. Volume has invalid encryption blob. |
65536973 |
Internal error. Volume DSID is missing. |
65537533 |
Internal error. Failed to unwrap SVM key encryption key. |
65537547 |
One or more volume encryption keys (VEKs) for this data SVM's encrypted volumes are stored in the key manager configured for the admin SVM. Use the REST API POST method "/api/security/key-managers/{source.svm.uuid}/migrate" to migrate these keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537556 |
ONTAP is unable to encrypt or decrypt because the configured external key manager is in a blocked state. Possible reasons for a blocked state include the top-level external key protection key is not found, disabled or has insufficient privileges. Resolve the external key manager key issues at the key manager's portal before running the rekey operation. |
65537565 |
Internal error. Failed to update the VDEK blob. |
65537610 |
Rekey cannot be performed while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent rekeying. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to re-run and complete the operation. |
65539200 |
The key custodian not provided with an external key value store. |
65539201 |
Failed to encrypt. |
65539202 |
Failed to decrypt. |
65539416 |
Internal error. Failed to parse the key value store response. |
65539436 |
Rekey cannot be performed while the enabled keystore configuration is being initialized. Wait until the keystore is in the active state, and rerun the rekey operation. |
65539437 |
Rekey cannot be performed while the enabled keystore configuration is being disabled. |
65539817 |
The Barbican Key Management Service is not configured. |
65539834 |
New Key ID not found. |
65539836 |
No Key Management Service configured. |
65539844 |
Failed to import the SVM-KEK. |
65539856 |
During the rekey internal operation, a restore operation failed. |
196608088 |
Internal error. Failed to get encryption operation status. |
196608352 |
Internal error. The encryption blob was not found in the RDB table. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
