REST API reference
Restore the keys for an SVM from a configured Barbican KMS
POST /security/barbican-kms/{uuid}/restore
Introduced In: 9.17
Restores the keys for an SVM from a configured Barbican KMS.
  • security key-manager external barbican restore
uuid
string
path
True
UUID of the existing Barbican KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
65539817
The Barbican Key Management Service is not configured.
65539842
Failed to restore the SVM-KEK on at least one node.
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
