Restore the keys for an SVM from a configured Barbican KMS
Restores the keys for an SVM using a configured Barbican KMS, which is essential for maintaining secure access to encrypted data within the storage virtual machine.
HTTP method and endpoint
POST /security/barbican-kms/{uuid}/restore
Introduced in
ONTAP 9.17
Usage notes
Restores the keys for an SVM from a configured Barbican KMS.
Related ONTAP commands
security key-manager external barbican restore
uuid |
string |
path |
True |
UUID of the existing Barbican KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65539817 |
The Barbican Key Management Service is not configured. |
65539842 |
Failed to restore the SVM-KEK on at least one node. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
