REST API reference
Create a qtree in a FlexVol or FlexGroup volume
POST /storage/qtrees
Introduced In: 9.6
Creates a qtree in a FlexVol volume or a FlexGroup volume.
After a qtree is created, the new qtree is assigned an identifier. This identifier is obtained using a qtree GET request. This identifier is used in the API path for the qtree PATCH and DELETE operations.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the qtree.
  • volume.uuid or volume.name - Existing volume in which to create the qtree.
  • name - Name for the qtree.
If not specified in POST, the values are inherited from the volume.
  • security_style - Security style for the qtree.
  • unix_permissions - UNIX permissions for the qtree.
  • export_policy.name or export_policy.id - Export policy of the SVM for the qtree.
  • qtree create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
export_policy
export_policy
Export Policy
ext_performance_monitoring
group
group
The user set as owner of the qtree.
id
integer
The identifier for the qtree, unique within the qtree's volume.
name
string
The name of the qtree. Required in POST; optional in PATCH.
nas
nas
path
string
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. This field is to be deprecated and replaced with nas.path.
qos_policy
qos_policy
When "min_throughput_iops", "min_throughput_mbps", "min_throughput", "max_throughput_iops", "max_throughput_mbps" or "max_throughput" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
security_style
string
Security style. Valid in POST or PATCH.
svm
svm
Required in POST
unix_permissions
integer
The UNIX permissions for the qtree. Valid in POST or PATCH.
user
user
volume
volume
Required in POST
Example request
  "_tags": [
    "team:csi",
    "environment:test"
  "export_policy": {
    "id": 100,
    "name": "default"
  "group": {
    "id": "20001",
    "name": "unix_group1"
  "id": 1,
  "name": "string",
  "nas": {
    "path": "/volume3/qtree1"
  "path": "/volume3/qtree1",
  "qos_policy": {
    "max_throughput": [
      "900KB/s",
      "500MB/s",
      "120GB/s",
      "5000IOPS",
      "5000IOPS,500KB/s",
      "2500IOPS,100MB/s",
      "1000IOPS,25MB/s"
    "max_throughput_iops": 10000,
    "max_throughput_mbps": 500,
    "min_throughput": [
      "900KB/s",
      "500MB/s",
      "120GB/s",
      "5000IOPS",
      "5000IOPS,500KB/s",
      "2500IOPS,100MB/s",
      "1000IOPS,25MB/s"
    "min_throughput_iops": 2000,
    "min_throughput_mbps": 500,
    "name": "performance",
  "security_style": "string",
  "svm": {
    "name": "svm1",
  "unix_permissions": 493,
  "user": {
    "id": "10001",
    "name": "unix_user1"
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
262245
Invalid field value.
262247
917525
The specified volume does not exist in Vserver.
917927
The specified volume was not found.
918232
Either volume.name or volume.uuid must be provided.
918236
The specified volume.uuid and volume.name refer to different volumes.
1703954
Export Policy name specified is invalid.
2621462
The specified SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be provided.
5242881
Cannot create qtree because the volume is read-only.
5242886
Failed to create qtree.
5242894
Qtree with empty name "" is not allowed, as that is reserved for the default qtree.
5242900
Qtree not supported on FlexCache volume
5242948
Qtree is not supported on FlexCache origin volume.
5242951
Export Policy supplied does not belong to the specified Export Policy ID.
5242952
Export Policy ID specified is invalid.
5242953
Qtree name must be provided.
5242967
UNIX user or group ID must be 32-bit unsigned integer.
5242970
FlexCache create is in progress for the volume.
5242978
The maximum number of qtrees for which extended performance monitoring can be enabled has been reached. Retry the POST request with ext_performance_monitoring.enabled set to false.
5242979
Qtree creation succeeded but failed to enable extended performance monitoring on the qtree.
6622064
Security-style NTFS is not supported on a SnapMirror active sync relationship volume.
8454348
QoS on qtrees is not supported because not all nodes in the cluster can support it.
9437324
The security style unified is not supported.
23724050
Failed to resolve user or group name.
66846755
Failed to determine whether volume is a FlexCache volume or not.
66846839
Failed to determine the effective cluster version of all the nodes hosting FlexCache volumes connected to FlexCache origin volume.
92405926
Qtree operation failed on the specified object store volume.
string
export_policy
Export Policy
id
integer
name
string
enabled
boolean
Specifies whether extended performance monitoring is enabled for the qtree.
group
id
string
The numeric ID of the group that owns the qtree. Valid in POST or PATCH.
name
string
Alphanumeric group name of group that owns the qtree. Valid in POST or PATCH.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
nas
path
string
qos_policy
max_throughput
string
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
min_throughput
string
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency observed at the storage object, in microseconds. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled with the next closest collection and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes does not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
Required in POST
name
string
uuid
string
user
id
string
The numeric ID of the user who owns the qtree. Valid in POST or PATCH.
name
string
Alphanumeric username of user who owns the qtree. Valid in POST or PATCH.
volume
Required in POST
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_tags
array[string]
export_policy
export_policy
Export Policy
group
group
id
integer
name
string
nas
nas
path
string
qos_policy
qos_policy
security_style
string
svm
svm
Required in POST
unix_permissions
integer
user
user
volume
volume
Required in POST
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
