Create a qtree in a FlexVol or FlexGroup volume
Creates a qtree within a FlexVol or FlexGroup volume when you need to organize and manage data hierarchically. This operation results in a new qtree with a unique identifier, which you can use for further management tasks.
HTTP method and endpoint
POST /storage/qtrees
Introduced in
ONTAP 9.6
Usage notes
Creates a qtree in a FlexVol volume or a FlexGroup volume.
After a qtree is created, the new qtree is assigned an identifier. This identifier is obtained using a qtree GET request. This identifier is used in the API path for the qtree PATCH and DELETE operations.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the qtree. -
volume.uuidorvolume.name- Existing volume in which to create the qtree. -
name- Name for the qtree.
Recommended optional properties
If not specified in POST, the values are inherited from the volume.
security_style- Security style for the qtree. -
unix_permissions- UNIX permissions for the qtree. -
export_policy.name or export_policy.id- Export policy of the SVM for the qtree.
Related ONTAP commands
qtree create
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_tags |
array[string] |
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings. |
export_policy |
Export Policy |
ext_performance_monitoring |
group |
The user set as owner of the qtree. |
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. Required in POST; optional in PATCH. |
nas |
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. This field is to be deprecated and replaced with nas.path. |
qos_policy |
When "min_throughput_iops", "min_throughput_mbps", "min_throughput", "max_throughput_iops", "max_throughput_mbps" or "max_throughput" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed. |
security_style |
string |
Security style. Valid in POST or PATCH. |
svm |
Required in POST |
unix_permissions |
integer |
The UNIX permissions for the qtree. Valid in POST or PATCH. |
user |
volume |
Required in POST |
Example request
"_tags": [
"team:csi",
"environment:test"
"export_policy": {
"id": 100,
"name": "default"
"group": {
"id": "20001",
"name": "unix_group1"
"id": 1,
"name": "string",
"nas": {
"path": "/volume3/qtree1"
"path": "/volume3/qtree1",
"qos_policy": {
"max_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"security_style": "string",
"svm": {
"name": "svm1",
"unix_permissions": 493,
"user": {
"id": "10001",
"name": "unix_user1"
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262245 |
Invalid field value. |
262247 |
917525 |
The specified volume does not exist in Vserver. |
917927 |
The specified volume was not found. |
918232 |
Either |
918236 |
The specified |
1703954 |
Export Policy name specified is invalid. |
2621462 |
The specified SVM does not exist. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5242881 |
Cannot create qtree because the volume is read-only. |
5242886 |
Failed to create qtree. |
5242894 |
Qtree with empty name "" is not allowed, as that is reserved for the default qtree. |
5242900 |
Qtree not supported on FlexCache volume |
5242948 |
Qtree is not supported on FlexCache origin volume. |
5242951 |
Export Policy supplied does not belong to the specified Export Policy ID. |
5242952 |
Export Policy ID specified is invalid. |
5242953 |
Qtree name must be provided. |
5242967 |
UNIX user or group ID must be 32-bit unsigned integer. |
5242970 |
FlexCache create is in progress for the volume. |
5242978 |
The maximum number of qtrees for which extended performance monitoring can be enabled has been reached. Retry the POST request with ext_performance_monitoring.enabled set to false. |
5242979 |
Qtree creation succeeded but failed to enable extended performance monitoring on the qtree. |
6622064 |
Security-style NTFS is not supported on a SnapMirror active sync relationship volume. |
8454348 |
QoS on qtrees is not supported because not all nodes in the cluster can support it. |
9437324 |
The security style unified is not supported. |
23724050 |
Failed to resolve user or group name. |
66846755 |
Failed to determine whether volume is a FlexCache volume or not. |
66846839 |
Failed to determine the effective cluster version of all the nodes hosting FlexCache volumes connected to FlexCache origin volume. |
92405926 |
Qtree operation failed on the specified object store volume. |
href |
string |
_links
export_policy
Export Policy
id |
integer |
name |
string |
enabled |
boolean |
Specifies whether extended performance monitoring is enabled for the qtree. |
group
id |
string |
The numeric ID of the group that owns the qtree. Valid in POST or PATCH. |
name |
string |
Alphanumeric group name of group that owns the qtree. Valid in POST or PATCH. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
nas
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. |
qos_policy
max_throughput |
string |
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
min_throughput |
string |
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency observed at the storage object, in microseconds. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency observed at the storage object, in microseconds. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled with the next closest collection and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes does not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
Required in POST
name |
string |
uuid |
string |
user
id |
string |
The numeric ID of the user who owns the qtree. Valid in POST or PATCH. |
name |
string |
Alphanumeric username of user who owns the qtree. Valid in POST or PATCH. |
volume
Required in POST
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_tags |
array[string] |
export_policy |
Export Policy |
group |
id |
integer |
name |
string |
nas |
path |
string |
qos_policy |
security_style |
string |
svm |
Required in POST |
unix_permissions |
integer |
user |
volume |
Required in POST |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
