REST API reference
Delete a cluster network security certificate configuration
DELETE /security/cluster-network/certificates/{node.uuid}
Introduced In: 9.18
Deletes the certificate configuration for cluster network security for a given node.
Required properties
  • node: Node UUID
  • 'security cluster-network certificate delete'
node.uuid
string
path
True
Node UUID.
Status: 200, Ok
Name Type Description
_links
_links
certificate
security_certificate_reference
Security certificate object reference
node
node_reference
      "href": "/api/resourcelink"
  "certificate": {
    "name": "string",
  "node": {
    "name": "node1",
Status: Default
ONTAP Error Response Codes
Error Code Description
70320128
Modifying the cluster network security configuration requires an effective cluster version of ONTAP 9.18.1 or later.
70320132
The cluster has an out of quorum node, wait until all nodes are in quorum before modifying the cluster network security configuration.
70320137
The specified certificate was not found on the admin SVM
70320150
The certificate table is currently in use. Removing a certificate entry is not allowed.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
node_reference
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
