Delete a cluster network security certificate configuration
Deletes the certificate configuration for cluster network security on a specified node. Use this when you need to remove outdated or unnecessary certificate settings.
HTTP method and endpoint
DELETE /security/cluster-network/certificates/{node.uuid}
Introduced in
ONTAP 9.18
Usage notes
Deletes the certificate configuration for cluster network security for a given node.
Required properties
node: Node UUID
Related ONTAP commands
'security cluster-network certificate delete'
node.uuid |
string |
path |
True |
Node UUID. |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
Security certificate object reference |
node |
"href": "/api/resourcelink"
"certificate": {
"name": "string",
"node": {
"name": "node1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
70320128 |
Modifying the cluster network security configuration requires an effective cluster version of ONTAP 9.18.1 or later. |
70320132 |
The cluster has an out of quorum node, wait until all nodes are in quorum before modifying the cluster network security configuration. |
70320137 |
The specified certificate was not found on the admin SVM |
70320150 |
The certificate table is currently in use. Removing a certificate entry is not allowed. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
security_certificate_reference
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
node_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
