REST API reference
Retrieve a collection of S3 bucket snapshots
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots
Introduced In: 9.16
Retrieves a collection of S3 bucket snapshots.
  • vserver object-store-server bucket snapshot show
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
create_time
string
query
False
Filter by create_time
name
string
query
False
Filter by name
svm.name
string
query
False
Filter by svm.name
uuid
string
query
False
Filter by uuid
bucket_uuid
string
query
False
Filter by bucket_uuid
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_bucket_snapshot]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "bucket_uuid": "2aec8270-58e3-11ef-861e-005056ae1130",
      "create_time": "2024-08-21 20:18:04 -0400",
      "name": "snap1",
      "svm": {
        "name": "svm1",
      "uuid": "522b29a1-3b26-11e9-bd58-0050568ea321"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
Specifies the name of the SVM where this bucket exists.
_links
_links
name
string
uuid
string
s3_bucket_snapshot
Information about an S3 bucket snapshot.
_links
_links
bucket_uuid
string
create_time
string
Creation time of the snapshot. It is the storage unit access time when the snapshot was created.
name
string
The name of the snapshot. Snapshot names must start with a lowercase letter, a number, or a hyphen, must end with a lowercase letter or a number, and cannot exceed 30 characters.
svm
svm
uuid
string
The UUID of the snapshot in the bucket that uniquely identifies the snapshot in that bucket.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
