Retrieve a collection of S3 bucket snapshots
Accesses a collection of S3 bucket snapshots, which helps you manage and review snapshot data for storage operations.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots
Introduced in
ONTAP 9.16
Usage notes
Retrieves a collection of S3 bucket snapshots.
Related ONTAP commands
vserver object-store-server bucket snapshot show
s3_bucket.uuid |
string |
path |
True |
The unique identifier of the bucket. |
uuid |
string |
query |
False |
Filter by uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name |
bucket_uuid |
string |
query |
False |
Filter by bucket_uuid |
create_time |
string |
query |
False |
Filter by create_time |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_bucket_snapshot] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"bucket_uuid": "2aec8270-58e3-11ef-861e-005056ae1130",
"create_time": "2024-08-21 20:18:04 -0400",
"name": "snap1",
"svm": {
"name": "svm1",
"uuid": "522b29a1-3b26-11e9-bd58-0050568ea321"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
_links
self |
svm
Specifies the name of the SVM where this bucket exists.
_links |
name |
string |
uuid |
string |
s3_bucket_snapshot
Information about an S3 bucket snapshot.
_links |
bucket_uuid |
string |
create_time |
string |
Creation time of the snapshot. It is the storage unit access time when the snapshot was created. |
name |
string |
The name of the snapshot. Snapshot names must start with a lowercase letter, a number, or a hyphen, must end with a lowercase letter or a number, and cannot exceed 30 characters. |
svm |
Specifies the name of the SVM where this bucket exists. |
uuid |
string |
The UUID of the snapshot in the bucket that uniquely identifies the snapshot in that bucket. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
