REST API reference
Protocols s3 services svm.uuid buckets s3_bucket.uuid snapshots endpoint overview
Overview
An S3 bucket snapshot is an image of the bucket as it exists at the time when the snapshot is created.
S3 bucket snapshots can be created using scheduled snapshot policies set on the bucket, or user requested snapshot creations.
S3 bucket snapshot APIs allow you to create, delete, and retrieve snapshots.
Snapshot APIs
The following APIs are used to perform operations related to snapshots.
– POST /api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots
– GET /api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots
– GET /api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots/{uuid}
– DELETE /api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots/{uuid}
Creating an S3 bucket snapshot
The POST operation is used to create an S3 bucket snapshot with the specified name.
# The API:
/api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots:
# The call:
curl -X POST -k "https://<mgmt-ip>/api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots" -H "accept: application/json" -d '{"name" : "ss1"}'
# The response:
"job": {
  "uuid": "af10a4d1-60b3-11ef-82cf-005056ae1130",
      "href": "/api/cluster/jobs/af10a4d1-60b3-11ef-82cf-005056ae1130"
# The Job:
"description": "POST /api/protocols/s3/services/148b9bbd-58d8-11ef-b7ca-005056ae1130/buckets/2aec8270-58e3-11ef-861e-005056ae1130/snapshots/?name=ss1",
"state": "success",
"message": "success",
"code": 0,
"start_time": "2024-08-22T14:23:52-04:00",
"end_time": "2024-08-22T14:23:54-04:00",
"svm": {
  "name": "vs0",
  "uuid": "148b9bbd-58d8-11ef-b7ca-005056ae1130",
      "href": "/api/svm/svms/148b9bbd-58d8-11ef-b7ca-005056ae1130"
Retrieving S3 bucket snapshots
The GET operation is used to retrieve all S3 bucket snapshots for a specific bucket.
# The API:
# The call:
curl -X GET -k "https://<mgmt-ip>/api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots" -H "accept: application/json"
# The response:
"records": [
    "uuid": "20837456-3c8b-405a-aa3a-5300c048f87d",
    "name": "ss1"
    "uuid": "c67cd056-d386-477a-8378-fcc06987bedf",
    "name": "ss2"
"num_records": 2
Retrieving S3 bucket snapshots and all snapshot attributes
The GET operation is used to retrieve all S3 bucket snapshots for a specific bucket along with all the snapshot attributes.
# The API:
# The call:
curl -X GET -k "https://<mgmt-ip>/api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots?fields=**" -H "accept: application/json"
# The response:
"records": [
    "svm": {
    "bucket": {
      "uuid": "2aec8270-58e3-11ef-861e-005056ae1130"
    "name": "ss1",
    "create_time": "2024-08-22T14:23:54-04:00"
    "svm": {
    "bucket": {
    "name": "ss2",
    "create_time": "2024-08-22T14:30:42-04:00"
"num_records": 2
Retrieving the attributes of a specific S3 bucket snapshot
The GET operation is used to retrieve the attributes of a specific S3 bucket snapshot.
# The API:
/api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots/{uuid}:
# The call:
curl -X GET -k "https://<mgmt-ip>/api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots/{uuid}" -H "accept: application/json"
# The response:
"svm": {
"bucket": {
"name": "ss2",
Deleting an S3 bucket snapshot
The DELETE operation is used to delete an S3 bucket snapshot.
# The API:
# The call:
curl -X DELETE -k "https://<mgmt-ip>/api/protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots/{uuid}" -H "accept: application/json"
# The response:
"job": {
  "uuid": "94f97fa9-60b7-11ef-82cf-005056ae1130",
      "href": "/api/cluster/jobs/94f97fa9-60b7-11ef-82cf-005056ae1130"
# The Job:
"description": "DELETE /api/protocols/s3/services/148b9bbd-58d8-11ef-b7ca-005056ae1130/buckets/2aec8270-58e3-11ef-861e-005056ae1130/snapshots/c67cd056-d386-477a-8378-fcc06987bedf",
"state": "success",
"code": 0,
"start_time": "2024-08-22T14:51:46-04:00",
"end_time": "2024-08-22T14:51:47-04:00",
"svm": {
  "name": "vs0",
