REST API reference
Retrieve LUN maps
GET /protocols/san/lun-maps
Introduced In: 9.6
Retrieves LUN maps.
  • lun mapping show
lun.name
string
query
False
Filter by lun.name
lun.smbc.replicated
boolean
query
False
Filter by lun.smbc.replicated
  • Introduced in: 9.15
lun.node.uuid
string
query
False
Filter by lun.node.uuid
lun.node.name
string
query
False
Filter by lun.node.name
lun.uuid
string
query
False
Filter by lun.uuid
reporting_nodes.name
string
query
False
Filter by reporting_nodes.name
  • Introduced in: 9.10
reporting_nodes.uuid
string
query
False
Filter by reporting_nodes.uuid
igroup.replicated
boolean
query
False
Filter by igroup.replicated
igroup.uuid
string
query
False
Filter by igroup.uuid
igroup.protocol
string
query
False
Filter by igroup.protocol
igroup.os_type
string
query
False
Filter by igroup.os_type
igroup.name
string
query
False
Filter by igroup.name
igroup.initiators
string
query
False
Filter by igroup.initiators
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
logical_unit_number
integer
query
False
Filter by logical_unit_number
  • Max value: 4095
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[lun_map]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "igroup": {
        "initiators": [
          "iqn.1998-01.com.corp.iscsi:name1"
        "name": "igroup1",
        "os_type": "string",
        "protocol": "string",
        "uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
      "logical_unit_number": 1,
      "lun": {
        "name": "/vol/volume1/qtree1/lun1",
        "node": {
          "name": "node1",
          "uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
      "reporting_nodes": [
            "node": {
          "name": "node1",
          "uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
_links
_links
initiators
array[string]
The initiators that are members of the initiator group.
name
string
The name of the initiator group. Valid in POST.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group.
replicated
boolean
This property reports if the initiator group is replicated.
uuid
string
The unique identifier of the initiator group. Valid in POST.
node
The LUN node.
_links
_links
name
string
The name of the LUN's node.
uuid
string
The unique identifier of the LUN node.
smbc
"Properties related to SM-BC replication."
replicated
boolean
This property reports if the LUN is replicated via SM-BC.
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
_links
_links
name
string
The name of the LUN. Valid in POST. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
node
node
The LUN node.
smbc
smbc
uuid
string
The unique identifier of the LUN. Valid in POST.
node
self
reporting_nodes
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links
_links
name
string
The name of the node.
Either uuid or name are required in POST.
uuid
string
The unique identifier of the node.
svm
_links
_links
name
string
uuid
string
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
_links
_links
igroup
igroup
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
  • example: 1
  • Max value: 4095
  • Min value: 0
  • Introduced in: 9.6
  • readCreate: 1
  • x-nullable: true
lun
lun
reporting_nodes
array[reporting_nodes]
The cluster nodes from which network paths to the mapped LUNs are advertised via the SAN protocols as part of the Selective LUN Map (SLM) feature of ONTAP.
When a LUN map is created, the cluster node hosting the LUN and its high availability (HA) partner are set as the default reporting node. In POST, the property additional_reporting_node may be used to add an additional node and its HA partner.
  • readOnly: 1
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
