Retrieve LUN maps
Retrieves LUN maps to view the current mappings between LUNs and initiator groups. This is useful when managing and monitoring your storage configurations.
HTTP method and endpoint
GET /protocols/san/lun-maps
Introduced in
ONTAP 9.6
Related ONTAP commands
lun mapping show
Learn more
lun.uuid |
string |
query |
False |
Filter by lun.uuid |
lun.smbc.replicated |
boolean |
query |
False |
Filter by lun.smbc.replicated
lun.name |
string |
query |
False |
Filter by lun.name |
lun.node.uuid |
string |
query |
False |
Filter by lun.node.uuid |
lun.node.name |
string |
query |
False |
Filter by lun.node.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
reporting_nodes.name |
string |
query |
False |
Filter by reporting_nodes.name
reporting_nodes.uuid |
string |
query |
False |
Filter by reporting_nodes.uuid
logical_unit_number |
integer |
query |
False |
Filter by logical_unit_number
igroup.name |
string |
query |
False |
Filter by igroup.name |
igroup.initiators |
string |
query |
False |
Filter by igroup.initiators |
igroup.uuid |
string |
query |
False |
Filter by igroup.uuid |
igroup.os_type |
string |
query |
False |
Filter by igroup.os_type |
igroup.protocol |
string |
query |
False |
Filter by igroup.protocol |
igroup.replicated |
boolean |
query |
False |
Filter by igroup.replicated
replicated |
boolean |
query |
False |
Filter by replicated
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[lun_map] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"igroup": {
"initiators": [
"iqn.1998-01.com.corp.iscsi:name1"
"name": "igroup1",
"os_type": "string",
"protocol": "string",
"uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
"logical_unit_number": 1,
"lun": {
"name": "/vol/volume1/qtree1/lun1",
"node": {
"name": "node1",
"uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
"reporting_nodes": [
"node": {
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
_links |
initiators |
array[string] |
The initiators that are members of the initiator group. |
name |
string |
The name of the initiator group. Valid in POST. |
os_type |
string |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. |
protocol |
string |
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. |
replicated |
boolean |
This property reports if the initiator group is replicated. |
uuid |
string |
The unique identifier of the initiator group. Valid in POST. |
node
The LUN node.
_links |
name |
string |
The name of the LUN's node. |
uuid |
string |
The unique identifier of the LUN node. |
smbc
"Properties related to SM-BC replication."
replicated |
boolean |
This property reports if the LUN is replicated via SM-BC. |
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
_links |
name |
string |
The name of the LUN. Valid in POST. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume. LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
node |
The LUN node. |
smbc |
"Properties related to SM-BC replication." |
uuid |
string |
The unique identifier of the LUN. Valid in POST. |
_links
node |
self |
reporting_nodes
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
svm
_links |
name |
string |
uuid |
string |
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
_links |
igroup |
The initiator group to which the LUN is mapped. Required in POST by supplying either the |
integer |
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
lun |
The LUN to which the initiator group is mapped. Required in POST by supplying either the |
replicated |
boolean |
The |
reporting_nodes |
array[reporting_nodes] |
The cluster nodes from which network paths to the mapped LUNs are advertised via the SAN protocols as part of the Selective LUN Map (SLM) feature of ONTAP. When a LUN map is created, the cluster node hosting the LUN and its high availability (HA) partner are set as the default reporting node. In POST, the property For further information, see DOC /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes .
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
