REST API reference
Retrieve anti-ransomware auto enablement values
GET /security/anti-ransomware/auto-enable
Introduced In: 9.18
Retrieves the current anti-ransomware auto enablement values, including details about warm-up period and auto enablement setting for new and existing volumes.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
new_volume_auto_enable
boolean
Auto Anti-Ransomware Protection (ARP) setting for new volumes.
warm_up_period_applicable
boolean
Indicates if the warm-up period is applicable.
warm_up_period_completed
boolean
Indicates if warm-up period has completed.
warm_up_period_remaining_duration
string
Time remaining for warm-up period completion.
warm_up_period_total_duration
string
Duration of warm-up period.
      "href": "/api/resourcelink"
  "warm_up_period_remaining_duration": "string",
  "warm_up_period_total_duration": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
