Retrieve anti-ransomware auto enablement values
Retrieves the current values for anti-ransomware auto enablement, including details about the warm-up period and settings for new and existing volumes. This information helps you understand how these settings are configured in your environment.
HTTP method and endpoint
GET /security/anti-ransomware/auto-enable
Introduced in
ONTAP 9.18
Usage notes
Retrieves the current anti-ransomware auto enablement values, including details about warm-up period and auto enablement setting for new and existing volumes.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
new_volume_auto_enable |
boolean |
Auto Anti-Ransomware Protection (ARP) setting for new volumes. |
warm_up_period_applicable |
boolean |
Indicates if the warm-up period is applicable. |
warm_up_period_completed |
boolean |
Indicates if warm-up period has completed. |
warm_up_period_remaining_duration |
string |
Time remaining for warm-up period completion. |
warm_up_period_total_duration |
string |
Duration of warm-up period. |
"href": "/api/resourcelink"
"warm_up_period_remaining_duration": "string",
"warm_up_period_total_duration": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
