REST API reference
Retrieve an SAML service provider configuration
GET /security/authentication/cluster/saml-sp
Introduced In: 9.6
Retrieves a SAML service provider configuration.
host
string
query
False
Filter by host
  • Introduced in: 9.7
certificate.ca
string
query
False
Filter by certificate.ca
  • maxLength: 256
  • minLength: 1
certificate.serial_number
string
query
False
Filter by certificate.serial_number
  • maxLength: 40
  • minLength: 1
certificate.common_name
string
query
False
Filter by certificate.common_name
enabled
boolean
query
False
Filter by enabled
idp_uri
string
query
False
Filter by idp_uri
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
certificate
certificate
enabled
boolean
The SAML service provider is enabled. Valid for PATCH and GET operations only.
host
string
The SAML service provider host.
idp_uri
string
The identity provider (IdP) metadata location. Required for POST operations.
      "href": "/api/resourcelink"
  "certificate": {
    "ca": "string",
    "common_name": "cluster1",
    "serial_number": "1506B24A94F566BA"
  "host": "string",
  "idp_uri": "https://idp.example.com/FederationMetadata/2007-06/FederationMetadata.xml"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
ca
string
Server certificate issuing certificate authority (CA). This cannot be used with the server certificate common name.
common_name
string
Server certificate common name. This cannot be used with the certificate authority (CA) or serial_number.
serial_number
string
Server certificate serial number. This cannot be used with the server certificate common name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
