REST API reference
Retrieve cluster network security certificate configuration for a node
GET /security/cluster-network/certificates/{node.uuid}
Introduced In: 9.18
Retrieves the certificate configuration for cluster network security for a given node.
  • 'security cluster-network certificate show'
node.uuid
string
path
True
Node UUID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
certificate
security_certificate_reference
Security certificate object reference
node
node_reference
      "href": "/api/resourcelink"
  "certificate": {
    "name": "string",
  "node": {
    "name": "node1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
node_reference
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
